componet question...what is it...pic linked
Old May 28, 2007 | 06:31 PM
MikeFlorida's Avatar
MikeFlorida
The 2 links below go to a pic of a rod that is on the frame rail close to my back shock on an 86 f150 4X4. There is 1 rod & bracket on each side of the truck. I have looked through suspension breakdowns & cannot find out where they are sussposed to go. Any help is appericated.
Thanks,
Mike
http://i7.photobucket.com/albums/y269/Mikeflorida/bracket2.jpg
http://i7.photobucket.com/albums/y269/Mikeflorida/bracket1.jpg
Old May 28, 2007 | 07:32 PM
Butl85's Avatar
Butl85
Was about to say old exhaust hangers, but in a funny spot for that.
Old May 28, 2007 | 07:37 PM
MikeFlorida
Yeah there is one on each side of the truck & both exhaust pipes run along the passenger side. Probally 1 1/2 inches of threads on the end of the rod. kinda looks like an old end to a shock, but I do not see any where for a shock to hook up. Thanks for the reply.
Mike
Old May 28, 2007 | 07:57 PM
Mikestrucks's Avatar
Mikestrucks
i believe those are the connecting rods to a rear axle stabilizer bar. the bar bolts to the rear ax;e with u bolts and the ends hook to these rods, giving your rear axle better stability.
Old May 28, 2007 | 08:10 PM
Franklin2's Avatar
Franklin2
I agree, it does look like the rear sway bar brackets. Here's a picture of the system.
http://www.lmctruck.com/icatalog/fd/0111.asp
Do you have dual front shocks? You may have the tow package.
Old May 28, 2007 | 08:21 PM
MikeFlorida
Yes it has Dual front shocks. The pic you posted looks like it could be the part thats missing. I will have to start scouring the junk yards again. It is also 4X4. Thanks for the replys Mike & Dave.
Mike
Old May 28, 2007 | 08:22 PM
CaptGuz's Avatar
CaptGuz
looks like the typical tracbar type setup for a rear axle... if you do towing i'd suggest hookin it all back up for less wear and tear on the axle/suspension and drivetrain
Old May 28, 2007 | 08:35 PM
MikeFlorida
It looks like 1980 thru 1996 f150's had the same type linkage, so "Maybe" I will get lucky & find one at my local junk yard. I surely don't want to spend the price of a new one. Thanks for the reply.
Mike
Moore558
13
Jan 27, 2008 12:46 PM
Moore558
Paint & Bodywork
Dec 13, 2007 10:02 PM
Nectar
Jun 20, 2007 08:44 PM
klatt_89
Appearance & Dress-Up
Nov 17, 2006 12:46 AM
bandaman
Nov 23, 2005 04:25 PM
