Sponsored by: Real Truck
headlight bulbs
Old May 28, 2007 | 05:44 PM
joeyj's Avatar
joeyj
headlight bulbs
what are the best <brightest> upgrade bulbs for a 2005 250 superduty.i notice on most 250,s the passenger side window trim,bottom moulding parallel to roof, is folded out ,i just got mine replaced ,warranty,
Old May 28, 2007 | 06:54 PM
ReAX's Avatar
ReAX
If you have aerodynamic headlights, you don't have a lot of options. The aero headlights use a 9008 bulb and Piaa isn't making them yet, so silvania is probably your best bet.
If you have non-aerodynamic headlights, you should upgrade to aerodymanics.
Old May 28, 2007 | 07:25 PM
dougc's Avatar
dougc
I like the Silver Stars from Sylvania. I hvae them in my 2005 and the night is lit up!
Old May 29, 2007 | 01:16 PM
389sixpack's Avatar
389sixpack
I use Sylvania Silver Stars. They work nice. Not sure about life yet. Had them in about 9 months.
Old May 29, 2007 | 01:18 PM
PHWLEE's Avatar
PHWLEE
I agree, the Silver Stars are a good "bolt on" replacement for the OEM's. Brighter and whiter.
Old May 29, 2007 | 03:00 PM
dfuser's Avatar
dfuser
We have 2 options for you Sylvania SS or LUXs Bulbs both rated at factory wattage.
Also you may want to upgrade and add the upgraded 9008 headlight harness to increase voltage for better lighting.
http://www.dfuser.com/mfg/powerstroke/73/Accessories/lighting.php
Bill
Old May 29, 2007 | 03:50 PM
1's Avatar
Id look into an HID conversion you can find a descent setup on ebay for about $99 bux on ebay nowadays and they last a LONG time and are WAY brighter then any standard bulb you can ever get your hands on. Upgraded a number of my cars with the ebay kits and am VERY happy with the quality and the light output is rediculous compared to standard bulbs. Ill never buy standard bulbs again.
Old May 31, 2007 | 11:50 AM
harald's Avatar
harald
You should check out www.danielsternlighting.com for some really good info on lamps before you buy anything. BTW, GE Nighthawk bulbs are available at Walmart.
Old Jun 2, 2007 | 08:48 PM
DonJames's Avatar
DonJames
GE Nighthawks!
Old Jun 3, 2007 | 05:05 PM
BigGreen'77's Avatar
BigGreen'77
Silver Stars actually produce less light than factory halogen bulbs. They are a very successful ripoff.
Old Jun 3, 2007 | 05:40 PM
dfuser's Avatar
dfuser
Be carefull with what you read. This is a test done by an independent company:
http://www.dfuser.com/Install%20Guid...bs%20facts.pdf
Old Jun 3, 2007 | 06:37 PM
tdister's Avatar
tdister
Sylvania Xtravision and the harness upgrade...basically the silverstar without the blue coating. Not a huge difference on their own, but with the harness they do great.
I've found the Silverstars to be rather poor when it's raining/wet out, much like any other blue coated bulb.
I would recommend the Nighthawks also (it's clear too), but I don't believe they make them in a 9008 yet.
Old Jun 3, 2007 | 07:45 PM
BigGreen'77
I have spoke with Daniel Stern on multiple occasions, and the idea that SS's produce more light really frustrates him.
The bulbs, including the SS, that have a coating on the lens, will not produce as much light. The coating on the lens will "absorb" light.
A couple of good places to do bulb research are Daniel Sterns' site, and HERE
