Thermostat Question
Old May 28, 2007 | 01:26 PM
xxandymacxx's Avatar
xxandymacxx
Smile Thermostat Question
What Steps Are Involved In Reintalling A Thermostat
Old May 28, 2007 | 03:49 PM
f_ford_custom's Avatar
f_ford_custom
1) obtain correct thermostat/gasket and some spare coolant
2) drain coolant
3) locate and remove thermostat housing. (usually where upper rad hose connects to engine)
*NOTE* some engines do not have thermostat housing, the thermostat is held inside the hose connector by pressure applied by a screw in the thermostat.
4) remove thermostat
5) clean mating serfaces of thermostat housing
6) insert new thermostat in Block/head/manifold with spring facing engine
7) install new gasket. (I prefer dry, but you can use just enough sealant to hold gasket in place, if you use enough to squeeze out, it WILL clog radiator/heater core)
8) install thermostat housing and torque to 12-18 ftlbs with aluminum castings, 18-25 with cast iron.
9) reconnect any hoses taken loose, check all clamps/pet***** and refill with coolant. (no less than 50% coolant, no more than 70%).
10) crank vehicle and check for leaks. watch temp guage carefully, if there is any air trapped in system, the thermostat may not open properly.
**NOTE** repeat step 10 for next 5-10 warming cycles.
for more specific information, go to www.autozone.com , click on REPAIR INFO, and click REPAIR GUIDES, then select vehicle information.
