transfer case squeal
Old May 28, 2007 | 09:58 AM
strokr2core's Avatar
strokr2core
Cool transfer case squeal
I haven't posted on here for awhile, so please bear with me. My '96 ford f250 4wd diesel is squealing in reverse. At first I thought it was the rear wheel bearings, took everything apart, and $150 later, turns out it wasent them. Continued on my tangent and thought it was u-joints in the driveshaft. Bought 'em on a whim, started replacing those this morn, and played around spinning the driveshaft while the truck was in neutral (auto tranny), on jackstands, and blocked front wheels. I started hearing the squeal. After some nosing around, it sounds like it is coming from the transfer case itself. I don't know enough to know what to do next, and am running out of patience and dough with these trial and error tactics I seem to hold dear (haha). Any help would be gracious.
Old May 28, 2007 | 10:03 AM
strokr2core
sorry, I think I posted in the wrong forum. It really pays to pay attention, sorry.
Old May 28, 2007 | 11:17 AM
bigbadwolfe's Avatar
bigbadwolfe
your in the right forum but i dont have an answer for you someone will be along to help you soon hang in there buddy
Old May 28, 2007 | 11:20 AM
bigbadwolfe
did you check the t-case oil is it full pull the fill plug and see where its at i guess you can start there
Old May 28, 2007 | 02:58 PM
powerstroked162's Avatar
powerstroked162
Are you sure its the T-case? If it is the T-case it should be squealing through all the gears if it truely is the case. Check your tranny fluids, Im thinkin you have tranny issues. Just my $.02
Cowboy Steve
Old May 29, 2007 | 06:26 PM
strokr2core
thanks for in info guys. I've made sure all the fluids are full. after I soaked the driveshaft u-joints down with blaster to replace them anyway, I spun the shaft again just to spin it, and it was silent. I guess it helps not to overreact to a little prob as if the sky is falling. chalk one up for FTE and the guys who write in to help guys like me to keep on the level. thanks again!!
woodie
Dec 21, 2012 10:24 AM
pfb
Apr 2, 2011 08:12 AM
chris619
1978 - 1996 Big Bronco
Nov 29, 2010 05:57 PM
jkschneider
Dec 14, 2009 12:42 PM
hoxiii
Sep 23, 2007 06:55 PM
