Gas.
Old May 28, 2007 | 02:49 PM
CaptGuz's Avatar
CaptGuz
alright... well i certainly am not going to be putting 89 or 93 in it if all its gonna do is turn my engine bay into a tailgater's dream grill (dont have to bring one with me) ... lol
its 83 till i get everything routine done that the PO's (also could be substituted for peice of sh**s) did not do for the last 10 to 15 years of this 25 year old trucks life...
ugh.
Old May 28, 2007 | 05:34 PM
SuperSnake's Avatar
SuperSnake
ugh.
If you want to help clean your fuel system on your next fill up put a can of seafoam in before putting more gas in it will help get the water and some trash out of your tank.
Old May 28, 2007 | 06:11 PM
CaptGuz's Avatar
CaptGuz
where can you get that stuff cliff? i've heard about it on the jeep forums i used to belong to. Can't remember if advance/autozone carries it.
Old May 28, 2007 | 06:18 PM
SuperSnake's Avatar
SuperSnake
Yes they both do in a can white with red writing
Old May 28, 2007 | 06:22 PM
CaptGuz's Avatar
CaptGuz
sounds good - i think i'll try that in both tanks on the trunk and maybe the grand prix
Old May 28, 2007 | 06:26 PM
SuperSnake's Avatar
SuperSnake
yeah it will have instructions on the can on how to get rid of carbon build up
Old May 28, 2007 | 06:45 PM
CaptGuz's Avatar
CaptGuz
cool... sounds like its worth the $howmuch
Old May 28, 2007 | 06:46 PM
SuperSnake's Avatar
SuperSnake
Around 5.00 a can
Old May 28, 2007 | 07:10 PM
CaptGuz's Avatar
CaptGuz
worth it for a few extra MPG if ya ask me
Old May 28, 2007 | 07:11 PM
SuperSnake's Avatar
SuperSnake
It will help for sure.
Old May 28, 2007 | 07:14 PM
CaptGuz's Avatar
CaptGuz
good i'll get some thurs
Old May 28, 2007 | 07:17 PM
ncfirefighter46's Avatar
ncfirefighter46
well i never used that stuff and it might get you more mpg but they way i see it if it done that it is not that much, and if it was a lot in mpg the oil companies would have done bought the rights to it. if you want more MPG you need to change the gear ratio that will lower the rpms which in turn lowers the amount of fuel /gas being used. that is the key everyone is looking at the engine to improve MPG when it is the gear ratio. is the key.
Old May 28, 2007 | 07:24 PM
  #28
CaptGuz's Avatar
CaptGuz
but doesn't the amount of fuel being dumped in the engine or how clogged everything is robbing the engine of power therefore making you press the accelerator more and end up running rich which is gas wasted? slight difference between gas efficiency and gas consumption
  #29
SuperSnake's Avatar
SuperSnake
Adam it cleans the fuel system and also helps reduce the carbon
Old May 28, 2007 | 07:50 PM
  #30
CaptGuz's Avatar
CaptGuz
do you put it in the tank and leave it or put it in then fill up or what?
