Cold water leak
Old May 27, 2007 | 04:52 PM
DAB1973's Avatar
DAB1973
Cold water leak
I am new to this site and the 6.0 psd. I have recently purchased a 04' excursion with the 6.0 psd with 90,000 miles. my problem is not while i,m driving it or while the engine it warm but when the engine is cold there is coolant leaking from the right rear part of the engine. I know the 6.0 has had problems with there egr coolers but they will normally leak under press (in a hard pull) but mine leaks after the engine is cold. I can park the truck after driving it and there is no coolant leaking from the engine. When i get up for work the next morning there it is coolant on the ground, right rear part of the engine. As i was looking for the leak i noticed coolant drips hanging from the starter and trans lines i looked at the head gasket and there is coolant around it aswell. looks as if it is leaking from the egr cooler or hose. I do not want to start replacing parts to try to fix it, is there any diagnostic procedures to check this problem. Thanks this forum is great. my name is Doug.
Old May 27, 2007 | 04:55 PM
BowTieHatr's Avatar
BowTieHatr
pressure test the cooling system. more than likely you found the source as the cooler hose is a prone leaker.
welcome to the site doug. good luck on the fix.
Old May 27, 2007 | 08:04 PM
wiingnut's Avatar
wiingnut
welcome to the site Doug. Let us know what you find the issue is. You may be on the right track
Old May 28, 2007 | 07:44 AM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Take it to the dealer and let them do it for the $100 deductable on the engine warranty. You have it for 5yr/100K
Old Jun 20, 2007 | 06:35 PM
DAB1973's Avatar
DAB1973
Thanks guys this web site is great. sorry it took me awhile to post back what i found, but i went on vacation. i removed the turbo and found the egr coolant hose was leaking. I went to the ford dealer and purchased the new hose for about $28.00 and replaced it and it has not leaked yet. I bought the new Bully Dog triple dog and then went on vacation. We drove nearly 1400 miles round trip and the truck did great. 20 miles per gallon with 7 people and all luggage. thanks again for this forum.
Old Jun 20, 2007 | 07:24 PM
blackhat620's Avatar
blackhat620
DAB1973,
Glad you got your leak fixed. FYI becareful with the Bullydog, they are known to cause problems with the 6.0 & Torqueshift.
madhatt
Mar 13, 2014 05:05 PM
grcutter
Aug 18, 2011 12:24 AM
rmackie6661
Mar 3, 2011 03:53 PM
Brett's 6.0
Nov 13, 2010 08:40 PM
04Xcursion
Jun 10, 2007 11:27 PM
