AC belt issue
Old May 27, 2007 | 12:37 PM
vaman4215's Avatar
vaman4215
Question AC belt issue
Is there a trick to getting the 63 inch belt on the AC compressor?? I losened the compressor and moved it inwards (towards motor) as far as the limit of the lsot would go, but the belt still won't go on the pulley. Went back to advance and autozone and they say that's the longest belt they have...Hate to take the bracket or the crankshaft pulley sleeve off then force it on the belt...
Old May 27, 2007 | 12:59 PM
Bruce R Leech's Avatar
Bruce R Leech
go some whare else that has a 64 or 65 inch belt
autozone Ha
Old May 27, 2007 | 02:25 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Is their a trick to getting you to list the type of vehicle and engine size? It makes it rather difficult looking thrugh all the different A/C belts to come close to 63/65" but here's what I found. I assumed you have a V8: 1987 F250
351W = 61 5/8".
420 = 63 1/4"
460 = 62 1/8"
There are longer ones used on Econolines, but your profile says F250, so that's what I went with.
Old May 27, 2007 | 02:29 PM
vaman4215's Avatar
vaman4215
Apparently I didn't give it enough time for my info to show up in the bottom, signature info...I've got an 88 F250 with the 7.3L diesel....
Old May 27, 2007 | 02:51 PM
NumberDummy
Alternator = D5PZ-8620-T / Motorcraft JC-584 / 1/2" x 58 1/2"
A/C = E4PZ-8620-G / Motorcraft JC-634-LA / 1/2" x 63 1/4"
P/S = C9PZ-8620-GT / Motorcraft JC-604-L / 1/2" x 60 1/2"
Vac Pump = C9PZ-8620-C / Motorcraft JB-332 / 15/32" x 33 1/4"
Note that the number portion of the Motorcraft number is the approximate length of the belt. The two letter prefix is the width.
Source: 1980/89 Ford Light Truck Parts Catalog: Section 86; Page 44.
