Dropped EGT's
Old May 27, 2007 | 07:28 AM
fomoconut's Avatar
fomoconut
Dropped EGT's
I found a way to drop 25 degrees from my EGT readings . I simply turn my headlights on ! I wonder what I hooked my power line to / or maybe its a ground problem.
Old May 28, 2007 | 09:32 PM
MrMike06's Avatar
MrMike06
Its a ground problem. I had the same problem with my integra back in the day. Its an easy fix atleast.
Old May 28, 2007 | 10:29 PM
Storm's Avatar
Storm
Not quite a ground issue.. Sounds more like you tap'd the power off your headlight circuit.. My guess, not saying you did this.. You tap'd your power on wire for the lights on the gauges so when you flipped the headlight switch they came on.. If you tap'd the 12v power off that same harness then its on the same circuit..
ljfen
Feb 20, 2013 11:41 AM
whalebus2112
Nov 24, 2012 04:42 PM
mongo75
Oct 4, 2011 08:41 AM
dlibson
May 20, 2010 09:15 AM
kilroy99
15
Sep 14, 2005 04:03 PM
