welcome to FTE!! youll find lots of info here about almost everything about your truck and sometimes other stuff too. be shure to check out all the forums youll see what i mean.there's a few of us that have hot rod trucks and some with origanal truck and some just drive'm so your in good company here. i see in your post you have a bb400 well sorry to say a 400 isnt a bb its a 335 series. the 385 series are big blocks(370,429,460).
Hey welcome to the site congrats to you on the that truck i have to agree i love this bodystyle (i do love the mustangs too) but yeah there is a ton of info here so enjoy
You might want to consider swapping out that 400 for a 460. It's a straight bolt-in swap with the bellhousing pattern and motor mounts being the same for both engines, but the 460 has a bit more potential for some real power. Not that the 400 is a bad motor, it's just that it was designed as more of a smog motor and takes a bit of doing to get it up to its potential, while you already have the advantage of more cubes with the 460 right off the bat...
Well I Checked The Block Today Had A 352 On It (yeah No 400) So After Seeing That I Checked The Heads For A # And Found The 360/390 Code But It Has A 4bbl Intake That Looks To Have Never Been Tampered With I Thought They Had 2bbl's? Its Also A Power Steering Truck But Sometime Since It's Been Sitting Someone Has Taken The Resevoir And Lines She's Also Missing The Alternator And Carb.
