auto hubs
Old May 26, 2007 | 03:29 PM
Shovelhead 93's Avatar
Shovelhead 93
auto hubs
What is so bad about the auto hubs,I have an 87 f 150 with them,they seem to work ok,the right one likes to try and engage on its own after I stop using 4x4 but it works ok.
Old May 26, 2007 | 06:38 PM
Bruce R Leech's Avatar
Bruce R Leech
keep them serviced up and they will work good for the life of the truck. for mose peple that dont get off the rode much they are far easier to use. it is mostly the rock crawlers and mud bagers that change them out
Old May 26, 2007 | 09:29 PM
lostin90s's Avatar
lostin90s
They can work great . I have them on my truck still because they were new. But the autos are not reliable under stress. If you are going down road or need to get off wet grass they are fine.
Even with mine being new they pop out if backing up or rocking truck under stress. So I just use them in winter for my road truck and swap to manuals for in woods to get the fire wood. Other wise I carry a tow chain with me. LOST
Old May 27, 2007 | 12:46 AM
broughy84's Avatar
broughy84
I don't like the autolockers my fil has a set on his 4x4 and i really don't think they hold up very well. Especially if you are a serious offroader as i am.
Old May 27, 2007 | 06:11 AM
Skandocious's Avatar
Skandocious
I have posted about this several times before due to my awful experience with auto hubs. The problem with the auto hubs on these trucks (as opposed to vacuum lock hubs, for example) is that they are engage by centrifugal force. This means that they engage when your front axle shaft starts spinning. So whats the problem? Well when you are rollin' along in 4wd and for whatever reason you have to stop and end up rolling backwards a couple inches (or need to back up), when you come to a complete stop the hubs will DISENGAGE, then reengage when you start rolling again. Now if you change direction too quickly you will toast the hubs. This happened to me when I got stuck in a snow bank this last winter season. I was trying to rock myself out (yeah I'm a *******) and the hubs just took a ***** because I was going forward-back-forward-back. Long story short, those stupid hubs cost me $450 in tow and tire chain fees. Would much rather listened to the guys on the forum and swapped them to manuals BEFORE this happened. I'll never ever drive another Ford truck with auto hubs, BAD BAD BAD.
-Chris
Old May 27, 2007 | 08:03 AM
Shovelhead 93
I just like the fact that you dont have to get out to engage them,call me lazy but I used to hate getting out to lock unlock hubs.
Old May 27, 2007 | 08:41 AM
Saxon's Avatar
Saxon
On the Auto hubs, was the 5 screw cap version supposed to be better than the newer version which had 3 screw caps?
