03 Expedition a/c problem(electrical)
Old May 26, 2007 | 03:13 PM
sonnycov's Avatar
sonnycov
Angry 03 Expedition a/c problem(electrical)
my compressor works when I jump it straight to the battery, the light comes on when i push the button inside, but no voltage at the compressor. I have checked the fuses and they are fine. where else must i check or if there is a electrical diagram I can get online. Please someone help
Old May 26, 2007 | 07:38 PM
LxMan1's Avatar
LxMan1
Welcome to the forums
Sounds like it's low on freon and the low pressure switch is keeping it from coming on.
Old May 29, 2007 | 10:23 AM
Frankie 2 Times's Avatar
Frankie 2 Times
Manual or EATC????
Sonny,
Is your climate control system a manual or an Electronic Automatic Temperature Control (EATC) system. I use to be the systems engineer for Ford/Visteon Climate Control. I should be able to help, but need to know where to start because it makes a huge difference whether its a manual and an EATC.
Thanks.
Old Jul 13, 2007 | 10:17 AM
Paty's Avatar
Paty
where the ac port for 03 expedition
