???hego???
Old May 26, 2007 | 12:27 PM
woodly1069's Avatar
woodly1069
???hego???
I was wondering if anyone knows what the heck HEGO is...I am trying to get codes out of my 94' F150 and this is all I get. It says: "Left Bank Lean, Check HEGO". Any help would be greatly appreciated.
Old May 26, 2007 | 12:43 PM
Bruce R Leech's Avatar
Bruce R Leech
what is the # code you are getting?
Old May 26, 2007 | 12:52 PM
woodly1069's Avatar
woodly1069
looks like a #172 to me. This is in the second set of numbers. During the first set of numbers all I get is the number eleven, two times...
Old May 26, 2007 | 02:16 PM
jroehl's Avatar
jroehl
HEGO = Heated Exhaust Gas Oxygen (sensor). They're threaded into a bung on your exhaust pipes. Depending on your truck, you may have more than one.
Jason
Old May 26, 2007 | 02:36 PM
Bruce R Leech
if it is saying left bank lean then you have ether 2 or 3 on the 94 and you must have a V8 so it is probably the left one closest to the header.
BUT that doesn't mean it is bad it only means that it is getting a lean reading. could be and probably is another problem
