1978 - 1996 Big Bronco
fuel injector test
Old Jul 28, 1999 | 03:34 PM
chris_2's Avatar
chris_2
fuel injector test
My #7 cylinder seems to be dead. There is compression, and a spark, but pulling the wire when it is running shows no change in idle rpm. I now suspect the injector. How is it tested? I don't want to just change it if I don't know it is bad.
Old Jul 30, 1999 | 11:59 AM
Mulletwagon's Avatar
Mulletwagon
fuel injector test
Get an automotive stethoscope from your local parts store, the type with a solid probe. With the engine running, place the probe on the injector and check for the distinctive clicking which should be heard as the pintle seats. If there is no clicking either the injector is frozen or there is an electrical problem. There should be a constant 12 volts to the injector. The computer provides a coded ground signal to open the pintle valve. Hope this helps.
Old Aug 31, 1999 | 01:25 AM
Kyle's Avatar
Kyle
fuel injector test
To save the expense of the "stethescope", we used to use a "bionic ear". That's a piece of old garden hose about two feet long.
Old Aug 31, 1999 | 06:27 PM
Joe
Guest
Posts: n/a
fuel injector test
Old Jul 29, 2004 | 04:41 PM
bchitwood73's Avatar
bchitwood73
Can I test an injector by connecting its plug to a light, or a multimeter somehow?
