Shift lever linkage
Old May 26, 2007 | 05:27 AM
lowcan's Avatar
lowcan
Shift lever linkage
A bolt that connects the shift lever to the linkage in the steering column came out and fell on the floor. Where do I start to get access to replace the bolt? It looks like I need to remove the plastic cover between the steering wheel and the dash. If this is the case, how do I remove the ignition switch?
Old May 26, 2007 | 08:19 AM
bkcowboss's Avatar
bkcowboss
For key roller removal
OK you are going to need a skinny pokey thingey. (that is a technical term) I used the sharp end of a 12 volt test light . on the bottom of your steering column there are two holes, one has a screw in it the other has a small silver pin. Turn the Key one click on past the lock position push up a little more, you should see the roller pop out a little bit then as you are pulling out on the key roller assembly turn just a little bit more and it should come right out. I just tested it and it worked like a champ.
