1978 - 1996 Big Bronco
Rebuilt Engines
Old May 26, 2007 | 12:50 AM
sirkt's Avatar
sirkt
Question Rebuilt Engines
Has anybody heard of this company http://www.precisionengine.com/rebui...ury/index.html ?
I'm looking at their 302 for my FSB that i rolled, and want to hear some opnions/expirences with this company. I'm looking at part # 7824.
Thanks
Old May 29, 2007 | 03:37 AM
sirkt's Avatar
sirkt
bump..............
Old May 29, 2007 | 08:27 AM
Kemicalburns's Avatar
Kemicalburns
what are you goals and uses for this rig. are you stuck on running a 302 or are other motor swap options something you may consider?
personally i would have a local engine builder do my motor. you may pay a tad more but i always like knowing who is doing the work if i can not do the work myself which is rare.
Old May 29, 2007 | 10:06 PM
ag30265's Avatar
ag30265
I have heard of them but have never dealt with them myself. As kem said, if you can't do the work yourself you'll want to be reassured that the work will be warrantied and it won't cost you shipping and the work to remove and install. Another option is Jasper engines, I have dealt with them and had good luck with the foreign power plant that was purchased........3 year 36,000 mile warranty guarranteed from them, but they will cost you a little more upfront.
Old May 30, 2007 | 02:46 AM
sirkt's Avatar
sirkt
I am kinda set on the 302 because my rig got bad enough gas millage before the roll and I don't want to make it worse. Also this will (probably) not be the last motor I put in the truck. I need to get it on the road as cheap as possible and the pirce for this motor is very attractive. Lastly I've done the local engine builder route before for another project and it didn't turn out so well so thats why I'm looking for a company with a warranty.
Old May 30, 2007 | 09:18 AM
Kemicalburns
read the fine print. most places like this warranyt only if a shop does the install work. jasper is similar to that as well. just an fyi a 5.8 in these rigs get the same if not better mpg then the 5.0. reason is the 5.8 produces more torque at lower rpms making it easier to move our heavy rigs. for instance i had a 5.0 in my 88 running an aod,3.55 gears and 31" tires. i got 12 city and 14hwy. i swapped to a 5.8 running same setup and got 13city and 16hwy.
if you want quick, back on the road and you plan on a different setup later then locate a running 5.0 from a wrecking yard and swap that in. or for the same relative price and time get a 5.8 and swap that in. its no more work, you reuse your 5.0 efi harness,motor mounts, tranny and front accessories. just get a complete 5.8 from wrecking yard (thats what i did) and its a plug and play setup. you will need to get the Y pipe widened slightly or grab the Y pipe from a wrecking yard and depending on tranny get the proper flexplate/flywheel.
just showing you all the options is all. good luck and keep us posted.
Old May 31, 2007 | 01:25 AM
1pump's Avatar
1pump
I noticed you're in Moscow. You might run over to Lewiston and see Fred at K & F if he's still there. I haven't talked to him in a long time, but he's a good machinist and he stands behind his work.
edtahaney
General Automotive Discussion
Jan 18, 2015 12:50 PM
Stewart_H
Feb 1, 2012 11:49 PM
mercurymanfi
Sep 4, 2008 01:27 PM
FTE Ken
Site Announcements
Jan 19, 2006 06:28 PM
jake00
Car/truck Buying Advice
Jan 2, 2006 01:52 PM
