1978 - 1996 Big Bronco
running hot
Old May 25, 2007 | 10:07 PM
twisted's Avatar
twisted
running hot
man this last weekend is causing more problems.....after dunking it into a mud hole it hasn't been rite.ive dried all electrical,replaced and dried air duct,the water pump started leaking and it was over heating. i hoped replacing the water pump would take care of the over heating but it hasn't. i don't think the thermostat is bad as the upper hose is hot after running.
so iam thinking the radiator is possible covered with dirt where i can not see it.
whats the best approach to cleaning this ?
**EDIT**
it is/was dirty.
i took the shrowd off and iam spraying the radiator off with a garden hose.
Old May 25, 2007 | 11:19 PM
ubereal2's Avatar
ubereal2
I'd pressure wash/car wash the radiator...
Old May 26, 2007 | 12:01 AM
twisted's Avatar
twisted
i dont want ot go crazy with a pressure washer at a car wash.
is there a way to check if the fan clutch is shot ?
Old May 26, 2007 | 04:47 AM
Black Ford XLT's Avatar
Black Ford XLT
Twisted, i dont know of any way of checking the clutch(thermal fan.) change it , they are cheap. On my 85 f-150 i finally changed it after over 400000 miles it still turned strong but was getting a higher than normal temp reading . Think i paid 15 bux for mine Good luck
Old May 26, 2007 | 05:02 AM
muckypaws's Avatar
muckypaws
I'd have though you should be able to see visually if its working ok. at idle it should spin the fan, and at high revs it shouldn't
