Sponsored by: Auxito
Blinking o/d light when i drive hard
Old May 25, 2007 | 04:58 PM
PinkyRingz's Avatar
PinkyRingz
AFter I drive my '98 F150 4.6 automatic tranny for about forty minutes and I pass a vehicle or run the motor hard in that time the o/d light on the shifter starts blinking and continues to do so until i turn off the truck. No funny shifting, no weird noises, gauges read normal, tranny fluid level is fine and smells okay....whats the deal?
Old May 25, 2007 | 05:05 PM
Bluegrass 7's Avatar
Bluegrass 7
Read the code.
Old May 25, 2007 | 05:07 PM
PinkyRingz's Avatar
PinkyRingz
if by code you mean count the number of blinks...it blinks at a steady non-stop pace until the truck is turned off....stays off when restarted adn then blinks again after I pass a vehicle and so on and so forth.
Old May 25, 2007 | 06:12 PM
liquid 1's Avatar
liquid 1
I think he;s talking about getting the truck scanned to see if theres a code from haveing the problem..
Old May 25, 2007 | 06:41 PM
PinkyRingz's Avatar
PinkyRingz
lmao....oh....well, alright then!! lol
Old May 25, 2007 | 11:22 PM
Bluegrass 7
The blinking light tell's you there is a transmission problem.
It's not a true check engine light so the blink tells you to expect a transmission code when scanned out of the port below the dash.
There are so many 4 place/digit codes that it could not possibly be read by counting flashes and not lose counts and be accurate especially if there is more than one code present.
Old May 26, 2007 | 05:05 AM
PinkyRingz's Avatar
PinkyRingz
she's going in for an overhaul on monday i believe...i was waiting for the gmc to come back from the shop before i put this one in. In four days i shut down three trucks...go figure. The newest one is an '05 GMC Sierra (garbage, never buy one of these) that we got for dirt cheap from the dealer. Nuthin but problems from day one. Our '02 GMC Sierra 3500 dually with the duramax has continuous starter problems. My preferred bucket, the '98 FORD F-150 XL with 320000 kilometres on it, only started blinking the other day. This Ford has been the most reliable out of them all. Can't wait to get a newer one. Ford all the way baby!!
Old May 26, 2007 | 11:58 PM
StephenH's Avatar
StephenH
This is an easy $20/10 minute fix more than likely if your truck is 4x4.
Change your speedo gear.
MIL ON/DTC P0503/Erratic Speedometer/Shifting
Article No.
98-5-8
03/16/98
<TABLE cellSpacing=2 cellPadding=1><TBODY><TR vAlign=top><TD>^</TD><TD>LAMP - MALFUNCTION INDICATOR LAMP (MIL)
ILLUMINATED - DIAGNOSTIC TROUBLE CODE
(DTC) P0503 STORED IN MEMORY - 4X4 VEHICLES
ONLY
</TD></TR><TR vAlign=top><TD>^</TD><TD>TRANSMISSION - SHIFT CONCERNS AND/OR
ERRATIC SPEEDOMETER OPERATION -
ILLUMINATED - 4X4 VEHICLES ONLY
</TD></TR></TBODY></TABLE>LIGHT TRUCK:
1997-98 EXPEDITION, F-150, F-250 LD
1998 NAVIGATOR
Part F7TZ-17285-AA
worked for me. The plastic gear inside the tailshaft housing had play in it. Replace it with the above part number.
Old May 27, 2007 | 07:35 AM
liquid 1's Avatar
liquid 1
Wow , stephen now thats great info that could save someone lots of $$$..thanks for posting up..
Old May 27, 2007 | 09:35 AM
PinkyRingz's Avatar
PinkyRingz
hey man, my bucket is a 4x4, thats awesome dude, thanks!!
Old May 27, 2007 | 05:34 PM
StephenH's Avatar
StephenH
Lol. Only took me six months to figure out that ford had a replacement gear that stopped the annoying o/d light blink.
You can check the gear by pulling out your VSS and sticking your finger in the hole. The replacement gear has NO slop in it, so if the old one moves at all, replace it.
