need help reading an Oasis
Old May 25, 2007 | 02:41 PM
farmgirl's Avatar
farmgirl
Hello everybody - I hope it's not against protocol to just jump right in here. I have an Oasis report on an '04 6.0 Excursion and I could use some experienced advice on it.
Question 1: Where is the best place to post it?
Question 2: How do I post it? I tried just to copy and paste it and it was too many characters.
Thanks!
Old May 25, 2007 | 03:03 PM
wiingnut's Avatar
wiingnut
Try posting in 2 or 3 pages what ever it takes and let the guys know it's a continuation
Old May 25, 2007 | 03:25 PM
farmgirl's Avatar
farmgirl
Thanks!
Here is page 1:
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FMSU45P94ED18147 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 08-APR-2004 03-JUN-2004 152202 USA 3 6P07 010301 * 7820124 * B15 07 3127
AWS Claim Key: 1529661 Trx Code: 1 Labor Hrs: 1
Dlr Cd-Sub Cd: 07990 - * Name: BOB MOORE FORD Ph: 405-6163673 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:06-AUG-2004 Doc #:053147A
Cust Comments: (B15) CUSTOMER STATES DRIVERS FRONT DOOR HARD TO CLOSE
Tech Comments: 3131 L.F. DOOR IS HARD TO CLOSE CHECK L.F. DOOR ADJUSTED HINGES AND LATCH WAS TO FAR IN RECHECK DOOR CLOSES GOOD TECH 7067 B.A. Y
1FMSU45P94ED18147 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 08-APR-2004 03-JUN-2004 152202 USA 3 2G05 031405 * RECAL * D13 42 3127
AWS Claim Key: 1566484 Trx Code: 1 Labor Hrs: 3.9
Dlr Cd-Sub Cd: 07990 - * Name: BOB MOORE FORD Ph: 405-6163673 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:06-AUG-2004 Doc #:053147B
Cust Comments: (D50) CUSTOMER STATES DIESEL ENGINE HAS A THUMP WHEN BACKING OUT OF DRIVEWAY AFTER STARTING. ALSO ON HOT DAYS DIESEL ENGINE HAS A ERRATIC IDLE.
Tech Comments: PERFORM DIESEL ENGINE DIAG PER DIAG SHEET PASS REPROGRAM PCM
1FMSU45P94ED18147 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 08-APR-2004 03-JUN-2004 152202 USA 7 5G05 040001 * FRONT * H24 W6 8579
AWS Claim Key: 2979319 Trx Code: 1 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 07990 - * Name: BOB MOORE FORD Ph: 405-6163673 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:16-DEC-2004 Doc #:059139D
Cust Comments: STEERING WHEEL OFF CENTER
Tech Comments: 8579 WHEEL POSTION OFF CENTER S WHEEL
1FMSU45P94ED18147 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 08-APR-2004 03-JUN-2004 152202 USA 8 3A03 * * * * * * 13529
AWS Claim Key: 3511059 Trx Code: 04B24 Labor Hrs: 6.2
Dlr Cd-Sub Cd: 07990 - * Name: BOB MOORE FORD Ph: 405-6163673 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:24-JAN-2005 Doc #:060756A
Cust Comments: RECALL 04B24
Tech Comments: 13536 7D006 R&R TRANS & REPLACED RECALL 04B24G 6.2
1FMSU45P94ED18147 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 08-APR-2004 03-JUN-2004 152202 USA 14 5C01 050100 * 4782 * N51 42 17549
AWS Claim Key: 6114469 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 07990 - * Name: BOB MOORE FORD Ph: 405-6163673 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:22-JUL-2005 Doc #:068854E
Cust Comments: CLUNKING NOISE IN REAR WHEN BACKING UP AND THEN PUT INTO DRIVE, HAS HAD IN A COUPLE TIMES AND WE COULDNT HEAR PROBLEMS, CUSTOMER PULLED UP SERVICE BULLITIN 17727
Tech Comments: 17549 4602 R&R DRIVESHAFT & LUBED SLIP YOKE & ROAD TEST
Old May 25, 2007 | 03:26 PM
farmgirl's Avatar
farmgirl
Page 2:
1FMSU45P94ED18147 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 08-APR-2004 03-JUN-2004 152202 USA 16 * * * * * * * 18224
AWS Claim Key: 6687406 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07288 - * Name: JOE COOPER FORD OF SHAWNEE Ph: 405-2737701 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:30-AUG-2005 Doc #:04768701
Cust Comments: FSA 05S34 FICM HARNESS REPLACEMENT
Tech Comments: PERFORMED RECALL. OPERATIONS E AND G. 6108
1FMSU45P94ED18147 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 08-APR-2004 03-JUN-2004 152202 USA 16 2H02 030008 5C3Z 6F089 A D42 42 18224
AWS Claim Key: 6687405 Trx Code: S07 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 07288 - * Name: JOE COOPER FORD OF SHAWNEE Ph: 405-2737701 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:30-AUG-2005 Doc #:04768702
Cust Comments: CS VEH HAS LOW POWER AT TIMES WILL NOT ACCEL
Tech Comments: VERIFIED CONCERN. RAN KOER. VGT FAILED ON KOER. GAVE CODES P0299, P0404 AND P0405. REPLACED VGT AND ROAD TESTED. BOOST WAS NORMAL BUT EGR% WAS HIGH. INSTALLED NEW EGR AND ROAD TESTED. OK. EGR AND VGT PERFORMED NORMAL. RERAN KOER. PASS. 6108
AWS Claim Key: 6687404 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07288 - * Name: JOE COOPER FORD OF SHAWNEE Ph: 405-2737701 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:30-AUG-2005 Doc #:04768704
Cust Comments: FSA 05E15 EPS REPLACEMENT
Tech Comments: PERFORMED RECALL. REPLACED EBP CONNECTOR. REPLACED EBP SENSOR DUE TO INCORRECT PART NUMBER. RECALIBRATED PCM, TCM FICM. ROAD TESTED OK. 6108
AWS Claim Key: 6687403 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07288 - * Name: JOE COOPER FORD OF SHAWNEE Ph: 405-2737701 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:30-AUG-2005 Doc #:04768705
Cust Comments: FSA 59B01 TEST DRIVE
Tech Comments: ROAD TESTED OK. 6108
Old May 25, 2007 | 03:27 PM
farmgirl's Avatar
farmgirl
Page 3:
1FMSU45P94ED18147 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 08-APR-2004 03-JUN-2004 152202 USA 17 2H01 030008 4C3Z 6K682 AARM D42 42 18519
AWS Claim Key: 7361027 Trx Code: S07 Labor Hrs: 7.6
Dlr Cd-Sub Cd: 00852 - * Name: JOE COOPER FORD, INC. Ph: 405-7331611 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:13-OCT-2005 Doc #:011110A
Cust Comments: C S ENGINE HAS NO POWER.
Tech Comments: 18519 1961 7.6 HOOKED UP WDS AND MONITORED AND RECORDED PID DATA WHILE TEST DRIVING,CONFIMRED LOW POWER.RAN PERFORMANCE DIAG,OIL LEVEL OK,NO LEAKS,NO AIR INLET OR EXHUAST RESTRICTIONS,HAS CMDTCS P0299, P2262,KOEO PASS,INJECTOR BUZZ PASS,KOER P0299, P1408,P2263.REFLASHED PCM,TCM,FICM TO LATEST CALIBRATION LEVEL,HAS 55 PSI OF FUEL PRESSURE. WENT TO PINPOINT TESTS KA1 THRU
1FMSU45P94ED18147 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 08-APR-2004 03-JUN-2004 152202 USA 17 1G03 030507 3C7Z 8620 AC E19 14 18519
AWS Claim Key: 7361028 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 00852 - * Name: JOE COOPER FORD, INC. Ph: 405-7331611 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:13-OCT-2005 Doc #:011110C
Cust Comments: C S SQUEELING NOISE ON COLD START UP
Tech Comments: 18519 1961 041412A 1.2 1.2 CONFIRMED NOISE ON COLD START UP,BELT IS SQUEEK ING.RAN OASIS AND FOUNS TSB 04 14 12.REMOVED AND REPLACED BELT PER TSB.REASSEMBLED ALL. STARTED,NO NOISE.
1FMSU45P94ED18147 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 08-APR-2004 03-JUN-2004 152202 USA 28 2H02 030407 5C3Z 6F089 BA E29 42 27647
AWS Claim Key: 10212901 Trx Code: S07 Labor Hrs: 5.9
Dlr Cd-Sub Cd: 06950 - * Name: REYNOLDS FORD, INC. Ph: 405-3212411 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:30-AUG-2006 Doc #:081149A
Cust Comments: WF E29 CK ENG LIGHT WAS ON ALL WEEKEND WENT OFF TODAY HEAR FLAPPING NOISE WHEN TRANS UPSHIFTS
Tech Comments: 27656 PERFORMED STEPS 1 13 OF ENGINE PERFORMANCE DIAG SHEET. RETREIVED DTCS P0238, P0299, P0404, & P0478. PERFORMED TSB OP. 061803B (3.1 HOURS), CLEARED DTCS, ROAD TESTED, AND RE TESTED ALL PASS DTCS RECEIVED AND BOOST PRESSURE NORMAL.
1FMSU45P94ED18147 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 08-APR-2004 03-JUN-2004 152202 USA 35 1H03 030008 * 9F452 * D42 55 31028
AWS Claim Key: 11371910 Trx Code: S07 Labor Hrs: 7.6
Dlr Cd-Sub Cd: 06950 - * Name: REYNOLDS FORD, INC. Ph: 405-3212411 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:26-MAR-2007 Doc #:089771A
Cust Comments: ENGINE BARKS ON ACCEL, OR SHIFTING, LACKS POWER, ACTS LIKE TURBO AGAIN
Tech Comments: 31028 PERFORMED TSB OPERATION 061906A 2.0 HOURS PERFORMED TSB OPERATION 062302A 5.6 HOURS
Old May 25, 2007 | 03:29 PM
farmgirl's Avatar
farmgirl
Page 4: By the way, this Ex has less than 32,000 miles on it. It's on a dealer lot that is not a Ford dealer and I have not seen it yet. Thanks for any input!!!
OASIS RESULT:
1FMSU45P94ED18147
05/25/2007
07:38:51
FCXWS446
© Copyright 2002-2006 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 EXCURSION BODY STYLE
4 DR EDDIE BAUER 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
ATTENTION TECHNICIANS AND SERVICE MANAGERS:
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 06-23-02
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
06/03/2004
BUILD DATE
04/08/2004
SALE MILEAGE
00031
OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
03/26/2007
DEALER: Reynolds Ford, Inc.
WARRANTY CLAIM NUMBER: 089771 ODOMETER: 031028M
PART NUMBER PART DESCRIPTION QUANTITY
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 9T515A KIT-TUBE TRBCH OIL R 001 061906A 55 PLUGGED/RESTRICTED
3C3Z 9P455AB SE E/G/R VLV 001 062302A
OSP 001
4C3Z 6K682CBRM TURBO CHG-EXH DRIVE 001
9F452 TRANSDCR-EGR BACK PR 000
31028 PERFORMED TSB OPERATION 061906A-2.0 HOURS PERFORMED TSB
OPERATION 062 302A-5.6 HOURS
08/30/2006
WARRANTY CLAIM NUMBER: 081149 ODOMETER: 027647M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6F089BA ACTUATOR ASSY 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F2
000 6005F6
000 6005F8
000 6005F9
000 6005F11
000 6005F12
000 6005F13
000 061803B
000 6005F1X1
000 VERIFY60
27656 PERFORMED STEPS 1-13 OF ENGINE PERFORMANCE DIAG SHEET.
061803B (3.1 HOURS), CLEAR ED DTCS, ROAD TESTED, AND RE-TESTED-ALL
PASS DTCS RECEIVED AND BOOST PRESSUR E NORMAL.
Old May 25, 2007 | 05:24 PM
Storm's Avatar
Storm
Ok...
So far here's whats been done...
6 AUG 04
Left Front Door hinge readjusted, door closes fine now
6 AUG 04
Reprogrammed PCM
16 DEC 04
Straightened the Center Steer bracket
24 JAN 04
Performed RECALL 04B24, R&R'd Tranny and replaced as per Recall
22 JUL 05
Checked Driveshaft and performed Slip Yoke/Carrier Bearing lube
30 AUG 05
Replaced FICM Harness, chaffing
30 AUG 05
VGT Failed on Key On Engine On, replaced Turbo, EGT showed high, replaced EGT.
30 AUG 05
Replaced EBP Connector and Sensor due to wrong PN, Reprogrammed PCM and TCM
13 OCT 05
PCM/TCM/FICM reflashed to latest strategy
13 OCT 05
Replaced Engine Belt
26 MAR 07
EGR Cleaned or replaced (Thanks God_Hammy!!)
Old May 25, 2007 | 05:31 PM
God_hammy's Avatar
God_hammy
tsb 06-19-06 is to clean or replace the egr
DIrect from FORD...
ISSUE:
Some 2003-2007 F-Super Duty, 2003-2005 Excursion and 2004-2006 E-Series vehicles equipped with a 6.0L engine may exhibit one or more of the following symptoms. Malfunction indicator lamp (MIL) on with diagnostic trouble codes (DTCs) P0404, P0401, P0402, P1335, lack of power, or surge.
ACTION:
Follow normal Powertrain Controls/Emissions Diagnosis (PC/ED) led diagnostics for the symptom or code identified. If normal diagnostics lead to replacement of the EGR valve, use the following Service Procedure to clean the valve instead of replacing it.
SERVICE PROCEDURE
Remove the EGR valve following Workshop Manual (WSM), Section 303-08.
Remove the EGR valve O-rings and gasket.
NOTE: THE EGR VALVE MUST BE HELD VERTICAL WITH ACTUATOR ASSEMBLY ON TOP FOR THE COMPLETE PROCEDURE. DO NOT ALLOW CLEANER TO ENTER THE WEEP HOLES IN THE BOTTOM OF THE ACTUATOR. (FIGURE 1)
Soak the EGR valve with carburetor cleaner or injector cleaner to loosen deposits. Do not use brake cleaner, this can damage the actuator seal. (Figure 1)
To clean the seats of the valve, hold the pintle shaft at the upper pintle head crimp (Figure 1) and gently push it open against the spring. Once open, insert a soft object to hold the valve open.
NOTE: IF SOAKING (SUBMERGING) THE VALVE MAKE SURE THE FLUID DOES NOT ENTER THE WEEP HOLES OR ACTUATOR SEAL. FLUID IN THESE AREAS WILL CAUSE THE VALVE TO MALFUNCTION. (FIGURE 2)
Use a non abrasive pick or brush to break up deposits.
Use carburetor cleaner or injector cleaner to spray away remaining deposits.
Dry the EGR valve with compressed air.
Wipe the EGR valve clean using a clean shop towel.
With new O-rings and gasket install the EGR valve following WSM, Section 303-08.
Clear any DTCs and perform the key on engine off (KOEO) On Demand Self-Test to learn the new EGR closed position. Failure to due so could result in a false P0404 DTC.
Verify the repair by using IDS datalogger to take active command of EGR valve. Ensure valve passes EGR position test in Section 4 of the PC/ED.
NOTE: IF THE EGR VALVE PASSES THE POSITION TEST IN THE PC/ED THE VALVE SHOULD NOT BE REPLACED.
If the EGR valve does not pass the position test, replace the EGR valve.
The root cause of the coking must be corrected or the coking may reoccur. Check for TSB's related to coking and the other diesel operating systems that could contribute to coking (fuel, turbo, oil, air induction, vehicle maintenance).
Old May 25, 2007 | 05:55 PM
blackhat620's Avatar
blackhat620
Also on
30 August 2006
Repair turbo actuator assembly.
Looks like this truck suffered bad from lot rot.
Unless this truck is a really good buy, you may want to pass on it, IMO.
Old May 26, 2007 | 12:24 AM
farmgirl's Avatar
farmgirl
Thanks guys!
Sounds like the downside of a low mileage PSD.
We went to kick the tires on it tonight and somebody from two states away had already put a deposit on it and is supposed to come get it tomorrow. Sure was pretty...
Anybody have a diesel Excursion for sale?
Old May 26, 2007 | 12:34 AM
Storm's Avatar
Storm
Where you located?
Old May 26, 2007 | 02:30 PM
wiingnut's Avatar
wiingnut
Those people from 2 states over probably did you a favor. Good luck in your venture
Old May 27, 2007 | 12:00 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
I know its a fair way from where you are located, but:
https://www.ford-trucks.com/classifi...ct/14010/cat/5
Also, try posting in your local chapter, a local might know someone with one:
https://www.ford-trucks.com/forums/forum92/
Old May 27, 2007 | 07:43 PM
WishIhada7.3's Avatar
WishIhada7.3
id skip it...
