Squeaky Suspension
Old May 25, 2007 | 02:28 PM
92_FlareSide's Avatar
92_FlareSide
Squeaky Suspension
I drive a 99 Ranger 4x4, and I was just wonderin what the best way to make my suspension stop squeaking.
Old May 25, 2007 | 02:33 PM
Benaghetto's Avatar
Benaghetto
Lube it up. Hit all the grease zerts with a few pumps of grease. Maybe should a little silicone lube into some joints like where your IFS mounts. Otherwise check you shocks. If they're original I'd suggest replacing them even if they arent whats squeaking.
Old May 25, 2007 | 02:36 PM
RangerPilot's Avatar
RangerPilot
Hit all your bushings with some WD-40 or the like as well. If they stop squeaking, you can either re-lube them as you get the chance, or replace them.
Old May 26, 2007 | 05:55 AM
RnMEtt7500's Avatar
RnMEtt7500
I use white litheum grease when I installed the shocks, bushing, ect. no problems as of yet.
Old May 27, 2007 | 09:45 PM
92_FlareSide
thanks for the help.
