New to 4x4
Old May 25, 2007 | 10:56 AM
biltfordtough's Avatar
biltfordtough
New to 4x4
Ok, I might sound like an idiot here but I just purchased my first 4x4. It is a 1990 F-150 XLT Lariat with a 351W. It has manual locking hubs on it but I am not sure how you engage the 4x4 to use it. I know that you have to lock the hubs but then do you just put the transfer case into 4low, 4hi or whatever, or do you have to be moving first to engage the transfer case. Any help would be great since then I can go out and have some fun and not wreck anything too bad.
Old May 25, 2007 | 12:36 PM
95Ford4x4's Avatar
95Ford4x4
lock the hubs in first. 4hi can be engaged on the fly, but not over 55mph. 4 lo is engaged you have to be stopped and put tranny in neutral. you can't go over like 35mph or so when in low. and don't use 4lo on solid surfaces, you can cause binding in the drivetrain and break something. when you take it out of 4wd, shift tcase first into 2wd, then unlock hubs. you may also need to go backwards 10ft or so, then back forward to make sure the hubs disengage. hope this helps.
Old May 15, 2008 | 09:50 PM
maverick1701's Avatar
maverick1701
When you are in 4hi or 4lo w/out the hubs locked does the front axle act like an open front diff?
Old May 15, 2008 | 09:59 PM
Conanski's Avatar
Conanski
I'll add that you cannot use 4wd(4hi or 4lo) on clear pavement at all, there is no center differential so if you do anything but go straight ahead you'll produce binding and driveline damage is very possible.
If you leave the front hubs unlocked and shift the transfer case into 4ho or 4lo, the front wheels will recieve no drive torque so the vehicle will act like it's in 2wd.
Old May 15, 2008 | 11:08 PM
V8NAMESE's Avatar
V8NAMESE
When I bought the 350, I took it out for a test drive. When I asked if I could try the 4wheel. The previous owner (6 yrs.) looked at me and said I dont know how. I wanted to laugh.
Old May 15, 2008 | 11:30 PM
maverick1701
Thanks Conanski, I have always wondered about that
Old May 16, 2008 | 12:27 AM
gweeds's Avatar
gweeds
If you aren't sure weather or not you are going to need 4x4 on a particular trip, just lock the hubs. When the hubs are locked you can just move the lever from 4hi to 2hi as the terrain dictates.
They do get a little loud at freeway speeds. They do also increase drag, and therefore decrease fuel mileage, but I'm pretty sure the effects are minimal.
