Part number question for NumberDummy
Old May 25, 2007 | 10:10 AM
dbossman's Avatar
dbossman
Can you look up the part number for the engine gauge feed harness for a 1972 F250 (with a 390)?
It would be one with 4 terminals (coil, water temp, oil pressure, ac).
And, is it possible to determine if the part is interchangeable with any Mustang equivalent parts?
There are lots of Mustang wiring suppliers. I'm hoping to either find an NOS piece somewhere (unlikely), or find a reproduced Mustang part that will work on my truck.
Thanks!
Tim
Old May 25, 2007 | 11:47 AM
Mil1ion's Avatar
Mil1ion
IIRC, That section of the harness can be used from Ford cars that have guages or Lights from that era.
The difference for these systems at each end of the wiring.
BTw, There are more people than ND on here that can answer.
Threads are best made with the topic in them
Old May 25, 2007 | 12:50 PM
dbossman's Avatar
dbossman
Hmmm
Of course there may be more people who can answer.
Numberdummy has done a nice job of researching part numbers for me in the past. I greatly appreciate his help.
Just wanted to make sure he saw my post.
Often times, people respond without answering the question at hand. I'm sure you've seen that before.
Most Mustangs had 3 terminal connectors. I need a 4 terminal connector. The closest match I have found is for a 68 mustang small block with AC.
I bought one, but think its probably too short for an FE. I will test it out this weekend. May have to splice some more length into it. I'd prefer to get the right part.
