Mass air?
Old May 24, 2007 | 10:14 PM
Jrock909's Avatar
Jrock909
Mass air?
Guys can you strictly repin the factory 92 F-150 ECU Connector to accomodate for a mass air computer?
Old May 25, 2007 | 10:42 AM
Franklin2's Avatar
Franklin2
It would be hard for me to believe the programming would be the same for the different types of sensor inputs. Wouldn't it be best to get a computer that is optimized for the changes you make to the engine to take advantage of them?
Sorry, I am not too familiar with the details of the mass air conversion.
Old May 25, 2007 | 01:50 PM
ReAX's Avatar
ReAX
The connect into the PCM should be the same, you will need pin outs for the old and new PCM. You will also have to add the MAF harness and run it back to the PCM. Sensor should be the same, but I don't have any way to confirm that the ohms are matched.
