Replacing Fluids?
Old May 24, 2007 | 11:25 AM
cowboyty's Avatar
cowboyty
Replacing Fluids?
On my 1978 F250 XLT 400 4spd manual trans, part time 4x4, I am wanting to replace the fluids in the transmission, transfer case, front end, and rear end. I don't know when it was done last so I figured it wouldn't hurt. I would like to have an idea of the quantity of fluids each takes. But I do have some lubes on hand and this is what I have and planed on using. 10 qts of Mopar Gear Lube 75W-90, 4 qts of Mopar Gear Lube 80-90, and 6 qts of 75W-140 Synthetic. I also got about 10 to 12 tubes of limited slip additive too. But my 78 does not have limited slip. What would you recommend where? Thanks for your help.
Old May 24, 2007 | 11:30 AM
Mil1ion's Avatar
Mil1ion
Which model 4-spd do you have ?
Dana 44 - 4.0 pints
Dana 60 - 6.0 pints
Transfer Case - 4.0 pints
Old May 24, 2007 | 11:38 AM
cowboyty's Avatar
cowboyty
not for sure at the moment. I'd have to look tonight when I get home from work.
