turbo
Old May 23, 2007 | 10:59 PM
01redcrew's Avatar
01redcrew
so im good on the wheel and can order it but is it worth 60 bones??
Old May 23, 2007 | 11:00 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Yes, much cheaper than $425 for a housing.
powerstroked162's Avatar
powerstroked162
Much funner to install as well, lol
Cowboy Steve
Old May 23, 2007 | 11:02 PM
01redcrew's Avatar
01redcrew
thaanks alot guys for the fast replys it will be ordered hopefully soon. does the new wheel make any more boost or what ?
Old May 23, 2007 | 11:06 PM
PowerstrokeJunkie
its actually less efficient. Takes 2-3psi of boost and relocates the "surge point" to where not many trucks surge. But the expensive housing will make the same boost and flow more air.
powerstroked162
Helps with turbo surge. Its got a totally diffrent compressor map then your stocker. I believe it makes less boost as well.
Cowboy Steve
Old May 23, 2007 | 11:08 PM
01redcrew's Avatar
01redcrew
well id say it will be worth it for 60 bones
Old May 23, 2007 | 11:09 PM
powerstroked162
One of the better cheaper mods to perform on the PSD
Cowboy Steve
Old May 23, 2007 | 11:59 PM
Tenn01PSD350's Avatar
Tenn01PSD350
You will lose low end power, and gain nothing on the top end but reduce surge. Those are the facts of life. That safety on the top end is worth it to many but not me. I'm not giving anything away. There are many reasons folks quote for the older turbo wheel but I'm a firm believer that Ford abandoned the WW as a result of HP wars and the newer wheel answered that call until they went common rail.
So the WW eliminates surge at a cost. The latter wheel makes more power down low and across the board and "could" damage the turbo when maxed out, or fluttering/surging. The WW will reduce this symptom by reducing the performance of the turbo and therefore overall performance. You can almost visualize the diff in performance by looking at the diff in the vanes of both units.
So do you want the older impeller wheel or keep what you have? If longevity is your primary concern, the older WW is the way to go toning down the power, as with any engine.
Old May 24, 2007 | 12:06 AM
01redcrew's Avatar
01redcrew
well i just order the wicked wheel so i guess ill have to keep it and try it out now
Old May 24, 2007 | 12:19 AM
1996pwrstrk's Avatar
1996pwrstrk
I installed a WW a couple of months ago,yes I lost a little on the bottom end but I can still roast all four tires on my dana 80 when I want too. I also have to be careful with the boost I have my waste gate disabled and it will swing 30+ to 35 easy so as far as losing boost I can't agree with that. It eliminated the bad surge I had between 1600 RPM to 2000 RPM and the sound is just fantastic.
Old May 24, 2007 | 12:23 AM
01redcrew's Avatar
01redcrew
does it make it louder or what does it do
Old May 24, 2007 | 12:25 AM
  #28
Tenn01PSD350
Well, the big selling point of the WW is surge elimination so choose based on your requirements. With any fooler or annihilator you may be good. I just think Ford didn't fall totally on their face with the later wheel. They do everything for a reason. You can bet they tested that too because of warranty reasons.
Old May 24, 2007 | 12:27 AM
  #29
01redcrew's Avatar
01redcrew
does it make the truck louder or what happens
Old May 24, 2007 | 12:33 AM
  #30
1996pwrstrk
With the open air filter set up and straight pipes it has a great whistle and mine being a manual tranny I get a WOOSH when I shift gears .
