diesel explorer
Old May 23, 2007 | 06:10 PM
Farmall05's Avatar
Farmall05
diesel explorer
I was wanting to know every ones opinions on putting a 4 cilinder diesel with a 5 speed in a 93 explorer. I know I have to do something with the ft springs to handle the weight. I should tell you the drive line is out of a 79 chevy lov so It is around the same weight as v8
Old May 24, 2007 | 07:20 PM
Matts72's Avatar
Matts72
anything is possible... let us know the details if you decide to do the project.
Old May 25, 2007 | 10:48 PM
Mtthwvn73's Avatar
Mtthwvn73
I wouldn't do it....your gonna be dropping at least 70 or 80 horses if not more, and getting probably the same mileage since that little 4 cylinder is going to be working it's a$$ off to get that explorer moving. It would be nice to drop a 7.3 in there, but I bet it would be rough to stuff in there....like shoving a 10lb turd in a 4lb sack.
Old May 26, 2007 | 12:56 AM
mwielgosz's Avatar
mwielgosz
What kind of diesel are you talking about? A little VW-sized diesel or a Cummins (or something similar)
Old May 26, 2007 | 04:05 PM
Mtthwvn73's Avatar
Mtthwvn73
a 4cylinder out of a chevy luv....
Old May 26, 2007 | 04:34 PM
nevrenufhp's Avatar
nevrenufhp
Those things barely moved a Luv, let alone an Exploder with about twice the weight. You need a bigger 4cyl, like a Cummins 4BT(3.9). Possibly a Cummins 'A' could fit, they are a little smaller & lighter than the B.
Old May 26, 2007 | 06:43 PM
Mtthwvn73's Avatar
Mtthwvn73
....or a 7.3...
Old May 27, 2007 | 02:00 PM
Farmall05's Avatar
Farmall05
A 7.3 would be nice, I was just thinking since I had the lov sittin around and the exploere had a bad engine and trans it would be a cheap swap but I did forget about the engine not realy wanting to move the lov around I may still do it Ill let yall know if I do something, thanks for the input
Old May 27, 2007 | 03:28 PM
mwielgosz's Avatar
mwielgosz
I defenately thinks its a cool project. If you end up going with it, you should document everything so we can check it out here
Good Luck
Old May 28, 2007 | 02:49 PM
Mtthwvn73's Avatar
Mtthwvn73
I think a nice swap would be dropping in a 300 in one. That would be something different for sure!
