302 heads
Old May 23, 2007 | 02:17 PM
1ole4d's Avatar
1ole4d
302 heads
What are your opinions on the C9TE heads. Would they be worthy of a rebuild for performance or the graveyard? I have read they have the 58cc chambers (can't remember if they were open or closed though) as compared to the 63 or 64cc heads of the 70's and up. I have a set along with the original 1970 302 block and crank. Are they worth anything?
Old May 23, 2007 | 06:23 PM
HemiEater's Avatar
HemiEater
if they are the same as the D0OE 302 heads (I think they are)then take a look.....These were my first set I ported, put 351W valves in them 1.85 1.54...
I had them on a supper flow something or other and these heads had 360hp potential.....thats what the sheet said anyways.
I just up loaded some pics of the flow sheet 44.8hp a cylinder ..
D0OE Heads
Old May 23, 2007 | 09:18 PM
1ole4d's Avatar
1ole4d
[QUOTE=HemiEater]if they are the same as the D0OE 302 heads (I think they are)then take a look.....These were my first set I ported, put 351W valves in them 1.85 1.54...
Apparently they are similar. I came across this earlier.
http://home1.gte.net/res03net/faqs/head.htm
Look at the cc's and the valve sizes. They are the same.
Old May 24, 2007 | 05:57 AM
HemiEater's Avatar
HemiEater
I wish I had them checked after I did more port work on the intake side.....it seemed to lay down after .350 lift......so I did some more work around the guide boss.
