1978 - 1996 Big Bronco
Passanger window
Old May 23, 2007 | 08:42 AM
Mike67's Avatar
Mike67
Passanger window
Yesterday I put the windows down on my way home from work, got home and the passanger side window would not go up, is there a way to put it up manually? I pulled the door panel off last night and dont see a way to take the motor off am I missing something?
Old May 23, 2007 | 09:13 AM
lostin90s's Avatar
lostin90s
The motor riveted on if never worked on. First check for power to switch . A bad switch can effect power from both sides. At least it happened to me. As a last effort you can try putting a jumper in or swapping switches if you have power if not you will have to do the motor thing . Remove vent window will allow you to move glass around try to get bottom arm out of window then track reinstall vent and frame and wedge window up till you figure out the problem . These motor die with no warning . It could be the gears but you would hear motor with door panel off .
There is probably a better way but its how I did it. When mine died in down .
Old May 23, 2007 | 10:25 AM
runder's Avatar
runder
My passage window in my 90 does the same thing, I got it back up by pulling the connector that goes to the motor in the door and hocked up to a battery pack from my cordless drill.
Old May 23, 2007 | 02:38 PM
Mike67's Avatar
Mike67
thanks for the info, I got home from work today and as normal I went to put the windows up and low and behold it came up, so I think it will stay up untill I can find the short in the system.
Thanks again ya'll
Mike
