1978 - 1996 Big Bronco
1990 Bronco Tailgate
Old Jun 8, 1999 | 01:53 PM
Lisa's Avatar
Lisa
Does anybody have any idea on how to keep the bottom of the tailgate from rusting out? I recently purchased the truck and all the ones (about 15 in all) I looked at had rusty tailgates. I would like to have mine repaired but I need to keep the water out so it doesn't happen again.
Old Jun 8, 1999 | 02:06 PM
berso's Avatar
berso
do you have consider buyin a fiber door? that may be about 300 dlls but you never have any rust again,and also take some pounds of your truk, i'm thinking to go for it,i fix my door about a year ago and its rust again,if you'r interested check at K bar S, you may order from them.
Good Luck.
Old Jun 8, 1999 | 11:17 PM
Lisa's Avatar
Lisa
Thanks for the info. It sounds like the fiber door is the way to go. Does K bar S have a website? I'll look for it.
Old Jun 9, 1999 | 01:40 AM
Branson's Avatar
Branson
K BAR S sounds like a good site --- Does anyone have the web address --- Thanks.....
Old Jun 9, 1999 | 05:51 AM
Ron-Bo
Guest
Posts: n/a
I got a new one on my Bronco a while back, and here's what I did to prevent the rust from coming back (5 years on Michigan salt roads). Peel the caulking off the bottom inside seam where the panels are flanged together. All it does is trap contaminants and make them rust the door. Squirt some oil occasionally down into the bottom inside of the door and let it seep into the folds at the bottom. You'll notice that the drain holes for the gate are higher than the seam where all the water sits
Old Jun 9, 1999 | 10:59 AM
berso's Avatar
berso
<a href="http://truckworld.com/KBARS/">http://truckworld.com/KBARS/</a>
Old Jun 9, 1999 | 11:11 AM
berso's Avatar
berso
<a href="http://www.bronco.com/lmb/bronco_glass.html">http://www.bronco.com/lmb/bronco_glass.html</a>
Old Aug 19, 1999 | 12:01 AM
Kyle's Avatar
Kyle
"Ron-Bo" has the right idea. My body shop buddy informed me that my Bronco's previous owner saved my flawless tailgate by drilling new holes at the bottom of it. Every single other Bronc had a rusty tailgate too, and I live in Texas.
Old Aug 27, 1999 | 10:35 PM
mikeb's Avatar
mikeb
>in Texas.
Old Aug 28, 1999 | 08:30 PM
mikeb's Avatar
mikeb
Lisa,
I guess I am the lucky one. I have an 85 and no rust in the tailgate at all. I recently replaced the window motor and while I had it apart I coated the entire inside bottom with a spray on rubber undercoating. I have had good luck with it in the past so I did it as a preventative measure.
Good luck.
Old Feb 27, 2000 | 09:12 PM
steakman_usaf's Avatar
steakman_usaf
When you guys drill those holes in the bottom of the tailgate, don't forget to grab a Q-Tip and soak it in spray paint and apply it to the small holes you drilled, to keep it from rusting around the holes..... Just a thought..... Hope it helps.
Old Feb 28, 2000 | 10:48 AM
xavetarx's Avatar
xavetarx
coastaldc
Jan 18, 2017 10:39 PM
jonrjen
6.7L Power Stroke Diesel
35
Aug 21, 2015 08:39 PM
IHateCommieCars
Jun 18, 2015 05:20 PM
stephendacosta
Mar 13, 2015 11:25 AM
peganit2
17
Jan 9, 2014 05:58 PM
