Sponsored by: Real Truck
electric brakes
Old May 22, 2007 | 05:32 PM
jhicks55's Avatar
jhicks55
electric brakes
I have a 2005 f-250 with the built in electric brakes system. At low speeds (below 15) mph the manuel lever does not work, is this normal or is something wrong. The manuel lever will also not stop the vehicle totally or keet it stopped.
Old May 22, 2007 | 06:22 PM
johnnysF350's Avatar
johnnysF350
I know that on my '06 the manual lever works below 15mph. As far as the lever not stopping your truck/trailer. More than likely your trailer brakes are worn out or need adjusting. When I fully engage my manual lever, the trailer brakes just about lock up and once I stop it will hold the truck in place.
Old May 22, 2007 | 06:52 PM
jhicks55's Avatar
jhicks55
thank you, I will check them, the dealership said they weren't sure at this point, they were doing some research. thanks again.
Old May 22, 2007 | 06:57 PM
Beerstalker's Avatar
Beerstalker
I want to say that the way your brakes are working is the way it was set up in 05, but in the 06&07s they fixed it. I am not sure though, hopefully someone else can come by and confirm that.
Old May 23, 2007 | 01:58 PM
jhicks55's Avatar
jhicks55
Well what I was told at the dealership is the electric brakes stop working at below 15 to 20 mph. They aren't sure why ford designed them that way but they are checking into a way of fixing it. I checked the trailer behind a vehicle that had an aftermarket e-brake system and they work great so it isn't brake adjustment. If anyone out there knows of a way to fix this problems let me know.
Old May 23, 2007 | 02:44 PM
tazo's Avatar
tazo
This was discussed before and as I recall they changed the controllers later on in production on the 05 models. My 05 was built 3/05 and my controller will work at any speed with just the brake pedal or the manual lever. I would check with your dealer and see if they can swap out the controller.
Old May 23, 2007 | 02:53 PM
jhicks55's Avatar
jhicks55
I am sending the e-mail now to Ford. thanks
Old May 23, 2007 | 04:47 PM
Biggziff's Avatar
Biggziff
Let me know how you make out. My 05 has the older style controller and I don't like not being able to do a "pull test" when hitching my fifth wheel up.
Thanks
Old May 23, 2007 | 05:14 PM
jhicks55's Avatar
jhicks55
I sure will. The dealership here is good but I don't think they will replace it without ford paying the bill. I will let you know the final. I have contacted Ford but no answer yet.
