copper lines
As for the price copper has gone up more then gasoline it seems every week you get a different net and engineers are starting to replace it with pex (plastic) more and more thats why I thought they didnt use it in the automotive industry.
So thanks for the info
Lui
Grumman used an A&N Rated SS Alloy on the F-14s that withstands 2500#psi up past Mach 2.25 and in a Salt Water~Air environment.
I've not tweaked a F-16, 18 or later, but I know only thing that hurts the plumbing on the Tom Cats was being struck by incoming.
I used a milder SS Alloy on my brake system. It is stable under any conditions I have yet to run across on land. It also can be undone without hassles later & without mylar or anti-sieze.
I think it's a "class" look. I know it's a last forever system. I like the look so much I ran a .375" dia Fuel line to feed my 460 & got plans to do A/T cooler lines when I get a "round tuit".
FBp
Yeah, I noticed they are well thought out for things like durability & function.
I just lose the redundancy of systems. The real benefit is, I only do stuff Once and seldom get stuck for equipment failures by following the lead of the A&N Boys. I use a cut down version of the composite Adels with only 1 pocket remaining. It's because I'm leary about applying alloy variety against steel framework materials & I only req 1 guide pocket per clamp, so I cut the rest off. 1 hold down fastener seems to do the job fine . . . . No Problems yet and no frothey for fuel either.
Isn't Dale Snodgrass from your neck of the woo' ? I recently caught him at a Air Show flying next to an F-15 eagle & Czech L-9 Albatross with his F-86 Republic Sabre. He lacked "blast", but once he got his candle lit he kept up great. . . . It was a sight!
FBp
