Computer Chips & Tuners
Tuning for mileage?
Old May 22, 2007 | 12:51 PM
Pinhead-227's Avatar
Pinhead-227
Tuning for mileage?
I found an article that touches base on this type of ECU tuning. You don't lose any WOT performance and you gain a lot of MPG. Here's the link:
Electronic Ways to Primve Your Fuel Economy
Specifically for the '98 Ranger 2.5L, are there any tuner programs/chips that are made specifically for part-throttle fuel efficiency? Does anyone know someone that can do this?
Old May 22, 2007 | 07:36 PM
Johnny Langton's Avatar
Johnny Langton
Some of that stuff in that link is right,some is not.
Losing the o2 sensor is BAD. There is no reference to stoich without the sensor,and the adaptive fuel strategy of the PCM is whacked without o2 sensor data to reference.
There are several methods of bettering fuel economy,and a good tuner will know how to do this. I could discuss it,but there are people that make their living tuning cars,so it wouldn't be fair to them to share the "tricks of the trade". It's not uncommon to get 2-3 mpg gain at part throttle cruise with a good tune.
JL
Old May 22, 2007 | 09:16 PM
Pinhead-227
2-3mpg isn't anywhere near 20%. How would it not be "fair"? There are people that make their living off of building mega horsepower engines, and that information is freely available.
Who are these people, BTW? I'd like to talk to them...
Old May 22, 2007 | 09:37 PM
Johnny Langton
Don't kid yourself-Those that make the mega horsepower engines don't share all of their secrets-if they did,they'd all be out of a job by some kid that makes the same power they do for less money.
There are several good tuners out there,and it's their decision to divulge information about proper tuning if they choose to. It takes a very intimate understanding of the control system to be able to setup a proper tune for ALL driving conditions.That's what seperates the tuners from the wannabes.
For a vehicle that gets an average of 13 mpg-a 2.6mpg gain IS 20% according to my math. Dunno where that 20% comment came from anyway.
I'm referencing a larger SUV or truck in terms of economy (2-3mpg) from a tune here-My TBird picked up 6mpg cruising with a good tune when it was still stock,but this isn't a Tbird forum,so that's a not a fair comparison.
JL
Old May 22, 2007 | 10:02 PM
ReAX's Avatar
ReAX
With a few tweaks, my sniper special forces gave me almost 6mpg on the highway. Of course I am not stock. However, special forces does give you some adjustment to spark and fuel curves to suit your needs.
Old May 22, 2007 | 10:04 PM
Pinhead-227
Sorry, the 20% came from the last paragraph in the article. We were just talking about different vehicles; 2-3 mpg isn't 20% of 30mpg. I'm building my engine for efficient power; the mods I'm planning have been done on a 2.5L/Auto that got 23mpg before and gets 29mpg now. That's without a tune and an automatic transmission. With the same mods (and a few more) I'm trying for as much mileage as I can get, hoping that I can push my 2.5L/5-spd Ranger into the 40mpg range with power comparable to a 3L V6.
Old May 22, 2007 | 10:09 PM
ReAX's Avatar
ReAX
Before you worry too much about tuning, I'd suggest volumetric efficiency tuning or even a supercharger. Deal with the mechanical first and then work on a dyno to get the tuning right. A supercharger should get you close to your goal, getting VE upto/over 100%, and then running right at or just below stoich at cruise speed with a modifier for WOT.
Old May 23, 2007 | 12:30 AM
Pinhead-227
I don't want to add a lot to the engine (turbo/supercharger); I want to use what's there and make it as efficient as possible. High compression, high turbulence, fast controlled burn, good fuel vaporization and mixing, and nice high-velocity ports. The engine part will be taken care of. I just don't want to have to "fight" the computer like you usually do when trying to get max mpg out of a car. Most of the mods that I want to do will decrease detonation and increase lean-burn misfire limits. In other words, I'll be able to run a lot leaner without worrying about hurting the engine or making it un-drivable. Trying to lean out a computer tuned engine can be a pain (the computer usually learns around the mods), and is why I was wondering who/where/how I could get my ECU tune for economy.
Edit: This is OBD2, right? (just checking)
Old May 23, 2007 | 07:18 AM
Johnny Langton
A '98 Ranger is OBD2,and if the base fuel calculations are setup in the PCM properly and the MAF transfer function is right,it won't learn around anything. Those that "fight" the PCM are not tuners,they're idiots that only know how to tune for WOT driving. I'll put it like this-if you've read about it on the internet,forget it-It's most certainly wrong or incomplete information that's from people that are clueless about tuning and/or still trying to tune with a screwdriver and a distributor wrench. The PCM is your friend-if you inform it of the changes you've made to the engine in the tables and scalars-it'll be able to accurately calculate spark and fuel for proper combustion.
JL
Old May 31, 2007 | 09:29 AM
bfloyd4445's Avatar
bfloyd4445
JL
Your right to a degree, however, from my experiance, and I am no expert, the PCM picks adjustments from a set curve stored in memory that dosen't change. The stored curve is designed around certain parameters, engine controls, and if you have modified your vehicle then that stored curve will only provide a ball park air/fuel ratio. To do a real tune a custom curve must be installed in the PCM if possible or external modifications must be made in order to compensate for the fixed PCM response.
Old May 31, 2007 | 02:20 PM
Johnny Langton
ABSOLUTELY NOTHING in the PCM is fixed or non-adjustable. The adaptive fuel tables,limits of adjustment,etc are all adjustable.
JL
Old Jun 3, 2007 | 03:55 PM
Pinhead-227
Getting back to this discussion... Does anyone know anybody that can tune strictly for mileage? All of the tuners I've ever heard of tune for added horsepower and get a little better mileage. Does anyone tune for added gas mileage and get a little more power?
Old Jun 3, 2007 | 04:54 PM
Johnny Langton
A properly tuned engine is more efficient,and will yeild more power at WOT. Better economy is a good side effect of a good tune.There are a few things that can be done to assist fuel economy,but alot of these things are tweaks to the tune that need to be done with the tuner in vehicle monitoring data as you drive.
JL
Old Jun 3, 2007 | 05:19 PM
99F150's Avatar
99F150
You need a custom tune. I have a 99 Ranger 2.5 and have a Diablo custom tuned chip. The chip has two tunes with a switch to change between the stock tune and the two on the chip. On tune 1 with E10 gas 89 octane my mpg increased by 3mpg. on tune 2 I have it set to burn E85, so far MPG is down 4.5mpg from E10 when running the E85.
Dan
Old Jun 3, 2007 | 08:10 PM
bfloyd4445's Avatar
bfloyd4445
Yep, glad you said that. I for one, would sure would like to hear the answer to your question. Well, anyone know a company that does this?
