1978 - 1996 Big Bronco
vacuum lines on 460
Old Mar 2, 2000 | 05:50 PM
bob's Avatar
bob
vacuum lines on 460
I'm replacing the engine in my 79 Bronco with a 460. I want to get the vacuum lines in correctly, but can't find a descript diagram to show them. Any info is greatly appreciated.
Old Mar 4, 2000 | 12:07 AM
misfit
Guest
Posts: n/a
vacuum lines on 460
from my experance you are better off if you cap them all it will clean up your engine copartment and save you alot of troble later , that is just my opion and make it look alot neater , thats what i did with a 400 in a 79 bronco and it runs great!
Old Mar 4, 2000 | 12:40 AM
Chad's Avatar
Chad
vacuum lines on 460
You need only the PCV, Vacuum advance, Power brake Booster if its there, everything else you can cap off....EGR valve and all its lines, thermal switches on the t-stat neck, etc....
Old Mar 6, 2000 | 09:31 AM
PAUL_2's Avatar
PAUL_2
vacuum lines on 460
Old Mar 8, 2000 | 04:26 PM
bob w's Avatar
bob w
vacuum lines on 460
Thanks for the advice. That seems a lot easyer than what I was planning on doing...I just might, not do anything!
