pto
Old May 21, 2007 | 11:26 PM
rusty7983's Avatar
rusty7983
Question pto
anybody got a pto on their truck? i tried to remove the shaft to replace a leaking seal on the pump/ tank side. i removed both set screws. i got one side slip joint free, the other won't budge. i need to fix as it leaks alot.
Old May 22, 2007 | 12:22 AM
Tha_Stepside's Avatar
Tha_Stepside
do you havea puller for the u-joint? Try that, if not heat is the way to go.
Old May 22, 2007 | 10:51 PM
rusty7983's Avatar
rusty7983
it fits so tight ( 3/8 inch) i couldn't get any thing in there. i may disassemble the ujoint and use a gear puller. anyone else with similar issues?
Old May 22, 2007 | 11:26 PM
Mrcorey5's Avatar
Mrcorey5
Maybe try an air chisel with a blunt end on the shaft at the same time pulling like heck on the yoke?
