Rear axle seal..
Old May 21, 2007 | 08:03 PM
4DOORSR's Avatar
4DOORSR
Rear axle seal..
Anyone change one yet? I pulled up to my house, got out to a smoking wheel. As soon as I smelled it, I knew what was wrong. Axle seals! I don't think I ran it dry but now I need a new seal and brakes. Anybody have a simular problem yet?
Old May 22, 2007 | 12:58 PM
rojo's Avatar
rojo
Both were replaced on my '04 4x4 scab at about 15k, under warranty of course.
Old May 22, 2007 | 01:20 PM
schneidz's Avatar
schneidz
both were replaced on my 04 scab at 31,000. it was the second time i had them look at this problem.
Old May 23, 2007 | 03:08 PM
Doogie S's Avatar
Doogie S
4DOORSR,
I have one leaky one that I plan on doing as soon as I can locate the proper installation / removal tool...
Looks to be a pretty easy job, but for some reason the Factory Manual states that the bearings and seals need to be removed as a unit, so I am looking for the proper tools to do the job. Rotunda makes them, I just haven't been able to locate any locally yet.
Also, Ford made three different rear ends for the trucks in 04, so you will need to know which one you have to order the proper parts. Mine is a 9.25", but an 8.8" & a 10.25" was also available.
Doug
PS: Anyone know if a finned aluminum cover is available for the 9.25"?
Old May 25, 2007 | 10:38 AM
rcknrbn's Avatar
rcknrbn
Rear seals
Originally Posted by Doogie S
4DOORSR,
Doug
Doug - I changed the rear axle seals in my '04 F150 4X4 under my garage a few months ago, probably took less than an hour. I had a friend helping me (very mechanically inclined guy, he had his face buried in the differential - admittedly, he did most of the work). We didn't use any special tools. I do remember there was some type of locking C shaped clip that had to be removed - a bolt holding it in place - had to be careful to line the axle grooves back up (sorry, I know I'm not being real specific). A 2nd person would be a plus.
I added a Mag-Hytec finned cover at the same time. Nice product, I think you would be pleased with it.
Old May 28, 2007 | 04:53 PM
Doogie S's Avatar
Doogie S
rcknrbn,
Thanks for the info. I'll definitely look into the cover.
Did you replace the seals and bearings at the same time or just the seals? I am leaning to replace both while I have it appart, as I sure don't want to have to open up the rear end again unless I have to.
Doug
Old May 28, 2007 | 07:44 PM
1saxman's Avatar
1saxman
I can't tell you right off hand how many vehicles I've had over the years with a live rear axle, but it's probably about a dozen, and I never have had a leaking seal or any other trouble. I thought I had a rear wheel bearing go bad on a '78 Pontiac Sunbird Formula, but it turned out to be a front wheel bearing. Just lucky, I guess. Ford must have had a problem with so many rear axle seal leaks turning up.
Old May 31, 2007 | 12:52 PM
rcknrbn's Avatar
rcknrbn
Seals
rcknrbn,
Doug
Doug - I only replaced the seals. I occasionally tow a 7000 lb. camper trailer and I know I've gotten the rear axle very hot on occasion. Seems that people who do some towing have leaking seals more than folks that never haul a load. Just my observation.
Old May 31, 2007 | 01:50 PM
Doogie S's Avatar
Doogie S
rcknrbn,
Interesting, as I really don't tow or haul that much otehr than my boat once in a while (around 3,000 lbs) and my crappy little utility trailer to the dump now and then.
She's basically an asphalt queen...
Doug
Old May 31, 2007 | 02:40 PM
FS-150's Avatar
FS-150
I attribute mine to getting too hot from a hanging parking brake. Replaced @ 35K miles under warranty.
Old May 31, 2007 | 08:38 PM
rcknrbn's Avatar
rcknrbn
Pics
rcknrbn,
Doug
I'm posting a couple of pics you may get a kick out of. I took these the day I changed my rear axle seals and installed the MagHytec finned cover. The differential previously got so hot it literally baked the paint off not only the differential cover, but the metal tags!
