one spark when key is let go
Old May 21, 2007 | 02:32 PM
80f1504x4's Avatar
80f1504x4
so theres only one spark after cranking and they key is turned back to acc. got a new coil just incase but thats not the problem. its an 80 f150 with a 351m. it has the duraspark system with the control module on the left side fenderwell. i read earlier that sometimes an ooze comes out of them? there is a liquid near it but havent taken the time to see if its just oil. i just replaced the engine and am tryin to get it started. Also i cant get fuel to the carb. the mechanical fuel pump that it came with looks to be new. i have all lines hooked up and there is gas at the fuel filter. ANy info would be great!
Old May 21, 2007 | 02:47 PM
Mil1ion's Avatar
Mil1ion
If it is a positional thing the problem is the Ignition switch.
Take jumper wire from the battery and attach it to the + terminal of the coil.
Try and start it.
If it starts and runs.. check the Ign RUN wire from the Ignition switch to the coil.
To check your ign module.
Old May 21, 2007 | 09:35 PM
Franklin2's Avatar
Franklin2
I would try changing the module.
As far as the fuel problem, was this carb off a running engine, and has been sitting a long time with fuel in it? If so, the float needle is probably gummed up and stuck. Try rapping on top of the carb with the plastic handle of a screwdriver and see if it breaks loose.
Old May 21, 2007 | 10:12 PM
82F100SWB's Avatar
82F100SWB
Pull the distributor cap, and have someone crank the engine, see if the distributor is turning. It could be you have a broken shear pin in the distributor, or a faulty module.
Old May 21, 2007 | 10:36 PM
Torque1st's Avatar
Torque1st
Posting Legend
The DS module will always spark once when de-energized or turned off. It can be a real "shocker" to anyone that does not know that.
Old May 22, 2007 | 12:35 PM
80f1504x4's Avatar
80f1504x4
ive tried the positive wire to the coil then to the battery to no avail. tried jumping the solenoid. tested coil and DS module. coil has 12 volts to it with key on DS has 12 volts with key on from one of the power wires but 8 on the other when cranking. was told it could be a possible ground problem or the pick up coil is bad. As for the fuel.....i took off the feed line to the carb and cranked it and there is no fuel coming out. fule pump "looks" new. theres gas on both sides of the fuel filter as well. so coil has power.... what makes it spark. this is the first time ive done a ford engine like this and its being a pain lol.
Old May 22, 2007 | 01:46 PM
Mil1ion's Avatar
Mil1ion
The pickup coil breaks the spark.
Old May 22, 2007 | 03:10 PM
80f1504x4's Avatar
80f1504x4
could the motor no being grounded properly have something to do with it?
Old Jun 9, 2007 | 04:18 PM
80 f-600 75 f-350's Avatar
80 f-600 75 f-350
hey i am new to the site but your spark problem, i had on my 80 f 600 with a 370 in it drove me nuts for a week same thing no spark only one when i let go turned out to be the two wires that go to the coil, the copper wire inside broke and the wire looked good from outside until i pulled it and it was like a rubber band ,check those ??
