brakes
Old May 21, 2007 | 11:06 AM
warlock-jim's Avatar
warlock-jim
Cool brakes
I HAVE REPLACED MASTERCYL. 6. TIMES BLED SYSTEM DRIVE TRUCK ALITTLE WHILE 20miles LOOSE PEDAL. I KEEP GETTING AIR IN THE REAR SYSTEM I WILL GRAVITY BLEED BOTH WHEELS. GET A FULL PEDAL AND IT STARTS ALL OVER AGAIN........BEEN HAPPENING FOR A MONTH..1993 F350 7.3 DUALLY......
Old May 21, 2007 | 01:21 PM
USMC Diesel's Avatar
USMC Diesel
If you can find a bleeder ball (Pressurized tank w/ break fluid) and force the new break fluid through it should clear everything out of the lines. Start with the furthest caliper from the master cylinder and work your way up. If that doesn’t do it than you have a bad caliper or a small hole in your break line.
