block casting #'s
Old May 20, 2007 | 09:21 PM
65f100_352's Avatar
65f100_352
block casting #'s
I was wondering if a FE with a 61 cast into the block above the 352 meant anything. I have found a motor at the dump, yes the dump, and was wondering if it is worth anything. the 352 in my 65 only has the 352 mark, as dose a 360 that i have.
thanks
Old May 21, 2007 | 05:21 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Nope not really. More than likely it's the part of the mold numbering system used when casting. If you can get it free see what heads,intake,crank and rods etc...are on/in it. Might make you a little extra cash selling the parts.
G.
Old May 21, 2007 | 09:45 AM
ranch67's Avatar
ranch67
look for a date code on the heads or intake.
C6XXX or C8XXX will start to tell you something.
block date is located under oil filter housing boss on left front of block.
save the FE if you can!
Old May 23, 2007 | 04:03 AM
f700's Avatar
f700
for free
Hi yes take it home the 1st chance you get they are gettting hard to find , well i would just take it as fast as i can ps long live the fe/ft s
