solid drop hitch?
Old May 20, 2007 | 09:02 PM
jake00's Avatar
jake00
solid drop hitch?
I need a solid drop (probably 6 inch) for a 2 5/16 ball. Does such a product exist?
Thanks
Old May 20, 2007 | 09:16 PM
mitchntx's Avatar
mitchntx
Solid?
I bought a 6" drop hitch tated at 1200lbs tongue weight and 12K tow. It wasn't solid, though. It was basically a thick wall piece of tubing welded inside the standard draw bar.
Old May 20, 2007 | 11:08 PM
blackhat620's Avatar
blackhat620
Thanks
Yep, Putnam hitch makes them, XDR solid steel 2-inch ball mounts, 15K wgt rating
www.putnamhitch.com/products_mounts.html#solid
Hope this helps
Old May 21, 2007 | 06:53 AM
thorseshoeing's Avatar
thorseshoeing
decadent and depraved
That's the only kind of drop hitch I've ever seen...what other type is there?
Tim
Old May 21, 2007 | 09:49 AM
tjc transport's Avatar
tjc transport
i ain't rite
Tim
silly wabbit, there are 2 types of hitches.
there are the solid bar stock that us perfessional towin type people use, and then there is the cheap hollow tube stock type the novice know-it-all wannabee towin type peoples use.
Old May 21, 2007 | 03:19 PM
rebocardo's Avatar
rebocardo
I think I bought my 10" drop (about 1.5 inches solid steel) from JCW for a 2" ball. Think it has a 1" hole. Was good for 10K and 1200 vertical if I remember the specs. It was a brand name, maybe Superior? Should be able to use a 2 5/16 if the shaft will fit.
Old May 21, 2007 | 06:57 PM
grafekie's Avatar
grafekie
There is nothing WRONG with a tube style drawbar... they just aren't rated for quite as much weight. Four of my six ***** mounts are hollow. The others are a pintle and a gooseneck. I tow with the hollow more than any other!
Old Jun 3, 2007 | 10:53 AM
jake00's Avatar
jake00
thank you everyone for the help
Old Jun 3, 2007 | 09:03 PM
Toyman's Avatar
Toyman
I have a billet aluminum 10K rated adjustable hitch. I pull so many different height trailers, it has 2" and 2 5/16" ***** on it and will raise 4" and drop 6". Quite costly (almost $200), but well worth the money.
Toyman
Old Jun 3, 2007 | 11:29 PM
jake00's Avatar
jake00
where'd ya get it?
Old Jun 4, 2007 | 06:19 AM
thorseshoeing
http://www.turnoverball.com/
Check out the "Tow and Stow Receiver Hitch"....I've thought about getting one of those.
Tim
