6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
fuel/water separator
Old May 20, 2007 | 12:22 PM
HoleG8r's Avatar
HoleG8r
When I took delivery on my 2008 F250 KR, the sales guy told me to pull the lever to release the water once a month. He even went on to say that if I pulled through the service department, they would do it real quick and I would not have to get out of my truck. So, I assumed a little bit of water would dump and that would be it. When I fliiped the lever this morning for the first time, it immediately smelled like diesel. I let it run for a few seconds to see if it would stop, but a sready stream continued. I cannot find any explanantion, instruction, or procedure in the manual or online about this. Thanks for the help!
Old May 20, 2007 | 06:07 PM
pinestar's Avatar
pinestar
the fuel will continue to run untill you shut it down
Old May 20, 2007 | 10:02 PM
NS F250's Avatar
NS F250
Well, I'm not sure how different the 6.4's are from the 7.3's, but the fuel/ water seperator is just a bowl that has both fuel and water in it. The water sinks to the bottom and would get drained first when you open the drain. Btw unless you get some bad fuel, you should net get a lot of water out of there. Fwiw, I only open mine during fuel filter change time. Don't know if thats the right way, but it's worked fine for the past three psd's I've owned.
Old May 22, 2007 | 09:09 AM
rondocycle's Avatar
rondocycle
went last night to look at the new trucks, draining the water sep. once a month was one of the first things the salesman stated. The injectors must be very prone to water damage, or they want to say you didn't do it properly and not warranty the injectors when they fail.
Old May 22, 2007 | 01:15 PM
blackhat620's Avatar
blackhat620
All injectors(7.3L, 6.0L, 6.4L, cummins, duramax) are damaged by water, draining the HFCM at least every 5K miles is good practice and if the "Water in fuel" light illuminates on the dash then you need to drain it sooner.
If you buy your fuel from reputable dealers that sell a high volume of fuel you should rarely get contaminated fuel.
hope this helps
Old May 22, 2007 | 02:39 PM
firehawk198's Avatar
firehawk198
Just drained mine for the first time today. 1200 miles only. Came out clear and could smell the diesel fuel. Drained only a couple ounces into a clear bottle. only a few droplets of water and the rest was fuel. Diesel has a slight yellow color to it.
Old May 22, 2007 | 04:48 PM
HoleG8r's Avatar
HoleG8r
Thanks for the input. I called the salesman that told me drain it once a month. He told me to write in my service log that I did it. So, it seems it may become a warranty issue if ignored. Thanks again for the responses!
Old May 22, 2007 | 05:04 PM
blackhat620
It appears that on page 60 of the 2008 Diesel Supplement manual that it says to drain the HFCM once a month. Also this information appears in the 6.0L Diesel Supplement manual.
Old May 22, 2007 | 05:12 PM
Paige Haddock's Avatar
Paige Haddock
I was given a DVD which describes this procedure and other maintenance procedures that must be performed on this truck. Ask your dealer where your DVD is.
