Sponsored by: Real Truck
Bilstien as stabilizer???
Old May 19, 2007 | 11:49 PM
Benny2002's Avatar
Benny2002
Question Bilstien as stabilizer???
Can you run a bilstien shock as a steering stabilzer? Anyone done it?
Old May 20, 2007 | 12:08 AM
TNT in Round Rock's Avatar
TNT in Round Rock
if I'm not mistaken, bilstein's are pressurized correct ? if that's the case you're going to have constant pressure on it so you'd be fighting it. Even with opposing duals, you're going to be fighting them either way.
you need a non pressurized dampner to do just that, dampen the load.
Old May 20, 2007 | 12:10 AM
Storm's Avatar
Storm
Steering Stabilizers and Shocks are two totally different animals.. Putting a pressurized shock on will cause you to either a) blow out the gear box, b) blow out the pump, or c) blow out both..
I just checked bilstien's site and they don't make any steering stabilizers..
Old May 20, 2007 | 06:36 AM
Benny2002's Avatar
Benny2002
Thanks it was just a thought I was hoping that they made a stabilizer
Old May 20, 2007 | 09:09 AM
Super08's Avatar
Super08
Also a streering stabilizer has to have 50 / 50 balance on rebound and damping which a standard shock does not.
Old May 21, 2007 | 07:06 PM
04F-250 stroked's Avatar
04F-250 stroked
look around!!! some people that have used a bilstein as a stabilzer! If i'm not mistaken the DR unit is a bilstein rebadged!
Old May 21, 2007 | 07:36 PM
Gage2502's Avatar
Gage2502
I might just get the Tuff Country dual stabilizers for my 2005 SD,
anyone have this brand? If so how do you like it?
I would be using this on my stock tires.
~Gage~
Old May 21, 2007 | 07:46 PM
75F350's Avatar
75F350
The pressurized shock will make the truck pull one way or another, depending on which way it is attached. In most single stabilizer ford applications the truck will pull to the right.
This is the reason shocks are mounted in opposite directions when used as stabilizers. If they are valved differently for rebound, and compression, they will cancell each other out, and work.
Also make sure that the shock can be used laying down. Some shocks can't, and if the gas, and oil are allowed to mix, the shock will be useless.
Dual stabilizers are really overkill for stock tires. I guess it looks cool, so if you are after style points, more power to you, but if you are installing that many dampers on the steering to compensate for worn components, you are opening a can of worms, and really need to fix the problems with the steering first.
Old May 21, 2007 | 07:50 PM
04F-250 stroked
check this out!
https://www.ford-trucks.com/forums/6...tabilizer.html
Old May 21, 2007 | 08:35 PM
brmpipes's Avatar
brmpipes
i have to two bilstein shocks on my stab on the front of my truck,works fine.Steering is firm and works well.
Old May 23, 2007 | 05:43 PM
mtgrzlyman's Avatar
mtgrzlyman
bilstein makes them for superlift i have them on my truck now
