Sponsored by: Auxito
Plug problem
Old Sep 29, 2002 | 11:18 AM
Ed2150's Avatar
Ed2150
Plug problem
I just changed my plugs on my 1998 F150 4x4 and that all I did now it run like crap and the check Eng. light comes so any help would be great.....Thank Ed
Old Sep 29, 2002 | 09:04 PM
Ultramagdan's Avatar
Ultramagdan
Plug problem
[updated:LAST EDITED ON 29-Sep-02 AT 10:05 PM (EST)]I would guess that you didn't get a coil pack "plugged" back in or that you broke one of the plugs during the installation process. It would also be possible to have a plug drop just before you got it to the threads and when that happened it pushed the tip up against the electrode.
Since you have a check engine light - read the code and see which cylinder is out.
Old Oct 2, 2002 | 02:27 PM
softball10's Avatar
softball10
Plug problem
i had the same problem when i first changed my plugs. at 1st i thought it was the plugs i used (bosch), i then changed to normal ac delco plugs. that didn't fix it, so i went and got a diagnosis. i changed out the wires and haven't had a problem since.
Old Oct 2, 2002 | 06:05 PM
bp460's Avatar
bp460
4wd Low
Post Plug problem
