1978 - 1996 Big Bronco
Idle Problem
Old Jul 11, 2000 | 12:29 AM
cee's Avatar
cee
Idle Problem
I have a 1988 Bronco with the 302FI. the odometer shows 106,000 & it has run fine for the last year. All of a sudden last week it will not hardly idle (does not idle up at cold start), & just barely stays running with the air on or with the steering turned hard. what should I check for first? Thanks
Old Jul 11, 2000 | 08:12 PM
slowtarget's Avatar
slowtarget
Idle Problem
If you don't have the check engine light coming on, I would clean the IAC valve. Pull the throttle body and IAC, get some carb cleaner and a old toothbrush. Scrub out all of the varnish and carbon. This does alot more than you think.
Old Jul 12, 2000 | 12:01 PM
berso's Avatar
berso
Idle Problem
