code 35
Old May 19, 2007 | 08:02 AM
bobcf's Avatar
bobcf
code 35
EVP circuit has intermittently failed above the maximum limit of 4.81 volts.
88 f250 460
the check engine light flashes at high high rpms.
I have a new egr a new egr position sensor. both of them work. I have new vacuume lines to the regulator and from the regulator to the egr.
Is the regulator letting too much vacuume thrue to the egr?
Is there a vacuume bleed off valve?
any other ideas?
Thanks
Bob
Last edited by bobcf; May 19, 2007 at 08:03 AM. Reason: forgot to idenify the motor
Old May 19, 2007 | 08:32 AM
subford's Avatar
subford
Code 35
Possible causes:
Damaged EVP sensor.
Short to power in harness.
Open in SIG RTN.
Damaged processor.
