I was told by the dealer that i have to replace all the injectors in my 2003 f-350 6.0 diesel. Does anyone know how much that should cost. The dealer told me $2618.00.
For High performance injectors, call Matt or Jeremy at www.lidiesel.com the have five stages of performance injectors. They are FTE sponsers, they may know an installer in MA also.
Also check down in the New England chapter section of FTE for recomendations on a good diesel mechanic.
Thanks
Are you beyond 100k miles? If not, they should be covered under your engine warranty.
They said all 8 had fault codes. Where can I get high performance injectors and have them installed in Massachusettes.
Thanks
Give Scott Hovey a call at Mass Diesel Performance 1-800-477-6127. They are located at 32 Production Road in Walpole, MA. I'm sure they can help you out.
Is your truck misfiring? Running rough? Hard to start? Fault codes at the same time for all 8 injectors is so rare that I would want more diagnosis. Just because you have codes, doesn't necessarily mean your injectors are defective.
Truck is running ruff, Then it is like someone is stabbing at the fuel while driving, and idles real high and the next minit it acts like it's starving for fuel. It has a mind of it's own!!
