Argh!
Old May 17, 2007 | 10:14 PM
Marty86's Avatar
Marty86
Argh!
I have a 86 f150, 2wd, auto, w/ the 300 carbed. I've rebuilt the engine, and transmission after it was sitting for 2 years. It seems I've replaced everything.
Here is my problem. It has issues starting. Obviously because its sitting, and hasn't been able to drive and use the atlernator to charge the battery, so we jump it off. However, it seems I have to pour a little gas in the the carb, just to get it to start. After that it'll stay started.
On top of this, I can't seem to get it timed correctly...is 10 degree BTDC correct?
Old May 17, 2007 | 10:19 PM
Mil1ion's Avatar
Mil1ion
Please title threads with the topic so we know what the thread is about
Never consider an alternator to charge a battery .
All they can be expected to do is top of the charge.
use a battery changer to charge a battery.
Hard start ?
Fuel can bleed back or disipate.
Try starting it every day for a while to see if it does better.
Have you disconnected the SPOUT connector before setting timing ?
Old May 17, 2007 | 10:40 PM
Franklin2's Avatar
Franklin2
Make sure the flapper door on top of the carb(the choke) is completely shut when you press the gas pedal to the floor once on a overnight cold engine.
Old May 18, 2007 | 11:26 AM
Marty86's Avatar
Marty86
I will remember that.
I put it on a charger last night, I'll check it when I get home from work today. Will try to start it up this afternoon, and post back.
Sorry about the thread title...
Old May 18, 2007 | 12:17 PM
Mil1ion's Avatar
Mil1ion
You might want to invest in a Battery Hydrometer to check the specific gravity of each cell.
SVTDriver97
Jun 16, 2014 07:47 AM
CDUB22
Jun 12, 2013 01:23 PM
edge03
Dec 5, 2009 08:44 AM
toms86ford
13
Apr 22, 2007 03:42 PM
SOCOM
May 11, 2004 07:34 AM
