Suspension Upgrade
Old May 17, 2007 | 06:11 PM
SuperSnake's Avatar
SuperSnake
Suspension Upgrade
I am picking up a 97 F150 front suspension with crossmember. Has anyone here modified one to a 81 F100?
Old May 17, 2007 | 07:22 PM
ri_truck_guy's Avatar
ri_truck_guy
I haven't tried it, but I'm really curious to see how it would work. Did it come with the steering gear? Any pictures?
Old May 17, 2007 | 07:24 PM
SuperSnake's Avatar
SuperSnake
I'll find out I should Pick it up this weekend. and I will take pictures. I was told it could be done and I want to try it since it give me a more modern suspension and I was told it will lower it too.
Old May 17, 2007 | 07:45 PM
ri_truck_guy
It looks like it can made to work with some frame fabrication. I found some drawings and picutres of both in some reference material I have here. The 97 is notched up and the crossmember and steering assembly mount from underneath. The 81 frame is straight, sandwiched between the cross member that mounts inside the frame, and the shock tower which mounts on the outside. It might be worth trying to get the front frame section from the 97 also...fabricating that section into the existing 81 frame might help keep the geometry straight.
Old May 17, 2007 | 07:56 PM
SuperSnake's Avatar
SuperSnake
thats what I plan to do I hope there is enough frame to cut and weld.So we can graft it on
