1978 - 1996 Big Bronco
94 bronco rear window problem
Old May 17, 2007 | 01:31 PM
hntr8183's Avatar
hntr8183
Question 94 bronco rear window problem
Whats up guys having a little problem with my rear window. The window goes down fine but wont go up. I was just woundering if the switch went bad or is it the motor? If the window goes down the motor should be good right? But i really dont know thats why im asking. Thanks for any help.
Old May 17, 2007 | 01:35 PM
bronconewby's Avatar
bronconewby
Search the threads for previous discussions of this topic. You should find what you need--welcome to the club, it happens alot with these broncos (I'm in the middle of it myself).
Old May 17, 2007 | 04:32 PM
hntr8183's Avatar
hntr8183
Thanks for the welcome. i will look through the threads.
Old May 19, 2007 | 09:19 AM
hntr8183's Avatar
hntr8183
I figured out my problem. I had a bad switch. I took the switch out and held the button in the up position and taped the switch with a screwdriver and the window went up. Thank for your help.
