Sponsored by: Real Truck
dies, with no codes set.
Old May 16, 2007 | 02:37 PM
COWBOYCADDILAC's Avatar
COWBOYCADDILAC
Question dies, with no codes set.
I have a 2002 f250 7.3l and if the engine is cold and you start up you can let it idle or go drive and will die once or twice at stops or idleing, if you start off with no stops it will not die and will not die after engine is hot. no check engine light on or codes stored in system. any body have some ideas as to what i can check.
thanks ,
Old May 16, 2007 | 03:08 PM
FortyFords's Avatar
FortyFords
Sudden death on 7.3 diesels are usually the cam or crank position sensor.
Most guys carry a spare .
Rich
Old May 16, 2007 | 03:34 PM
COWBOYCADDILAC
id heard that some wear and thought about tryin that , thanks.
