Passanger side lock not working
Old May 15, 2007 | 10:26 PM
Troutman69's Avatar
Troutman69
I just noticed this today that my passager side lock button does not work it will unlock but it wont lock if i keep pushing it it will lock so im just wondering what could be the problem im new to fixing trucks i just got this truck last month and it is my first ford its a 95 ford f150 white extended cab 4x4 with a 351 it has 172k miles and runs great i got it for $2750
Old May 15, 2007 | 11:13 PM
nobodyspecial's Avatar
nobodyspecial
The drivers side of my 95 F150 does the same thing, the best I could figure out is that when the button is pushed, the rod is binding somewhere along the line. Mine only does it sporadically, once every few weeks it wont lock. for me what happens is that the motor makes the movement to lock the door, but the plunger on the door only moves down a tiny bit like it is stuck. it wants to go, but wont. I just hit the lock button repeatedy and after a few seconds it goes down and works just fine for a while.
I would suggest taking the panel of and try to see if it binds anywhere. good luck
Old May 16, 2007 | 12:36 AM
Skandocious's Avatar
Skandocious
I agree. Sounds like the mechanism is binding. I'd remove the panel and hit it with some white lithium grease.
-Chris
Old May 16, 2007 | 03:50 AM
92F150Flare's Avatar
92F150Flare
My window switches were doing that.....seemed like the window was acting up. I sprayed some electronic contact cleaner down around the sides of the button and it helped a lot. There are contacts in there that get dirty over time. I'm sure you have some laying around....give it a try.
Good Luck
Old May 16, 2007 | 09:02 AM
nobodyspecial
92F150Flare, for me it didnt seem to be a contact problem, because the plunger on the door would try to move but it was like something was stopping it, the mechanism would make all of the movements, but the motion wouldnt get to the locking part. the switch worked every time, it was somewhere further down the line that was acting up.
