Trans cooler lines
Old May 15, 2007 | 09:42 PM
Americanmadeford's Avatar
Americanmadeford
Trans cooler lines
simple question. on my 302 AOD, which cooler line carries fluid to the radiator and which carries it away?
thank you!
Old May 16, 2007 | 12:14 AM
Franklin2's Avatar
Franklin2
When I installed the tranny oil cooler on my truck, they said to start it from an overnight sit, and run the engine for I believe about a minute or some very short time. Then they said to get under the truck right after you stop the engine and feel the tranny lines. One will be warm and one will be cool. The warm one will be fluid coming from the tranny and the cool one will be the return to the tranny.
I coud not believe it, it actually worked and you could feel a difference even after such a short period of running it, not even moving the truck out of park.
Old May 16, 2007 | 07:51 PM
Americanmadeford
Thats some pretty quick heat!
I just installed a trans. temp gauge. I installed it on the feed line for the radiator instead of the return line which carries the cooled fluid. How fast should I expect the transmission to warm up? I drove the truck around for about 5 miles or so. Shifted in and out of o/d a few times. The engine got up to 170*F but the gauge onyl got up to 100F, maybe 110F at the end of the trip. Does this sound normal or do I need to do some troubleshooting with the gauge?
Thanks Mr. Franklin
Old May 16, 2007 | 09:01 PM
Franklin2's Avatar
Franklin2
Don't really know what the temp of the tranny fluid should be? Maybe someone else has a tranny temp gauge and they could tell you what theirs runs.
Old May 16, 2007 | 09:04 PM
Americanmadeford
Your not saying I finally stumped you are you? Took me 10 or so posts but Ive finally dont it!
Old May 16, 2007 | 09:39 PM
Piffery1's Avatar
Piffery1
I have an old Faria transmission temperature gage on my '83 F350 (460/C6) and it runs about 160-165 deg. F. unloaded and about 180-185 deg. F. loaded. I checked my gauge readings against readings from my thermocouple type refrigeration temperature gauge with the thermocouple sensor clamped about 1" from the Faria sensor on the line from the transmission to the cooler and there was only about +2 deg. F. difference between the two (Faria higher) at 160 deg. F. indicated on the Faria. That's with the recommended 195 deg. F. engine thermostat. I've noticed that the engine reaches maximum operating temperature much faster than the transmission especially with no load on the truck. To get a real feel for what's happening you may need to put 500 or so pounds in the truck (or a loaded trailer behind) and take a 20-30 minute trip at highway speeds.
Old May 16, 2007 | 09:42 PM
Americanmadeford
Where is the sender for that gauge located, Piffery?
Old May 17, 2007 | 01:15 AM
Piffery1's Avatar
Piffery1
About 3-4" from where the line FROM the transmission enters the top port of the radiator cooler unit. There is a brass compression type "Tee" in the line and the sensor threads into the side port of the "Tee".
